Receiver settings
JOPARE
JOPARE Posts: 2
edited March 2011 in Electronics
So I just got everything set up for my home theater. I ended up with TSI200's for fronts, CS10 center, and rci55 in wall for the rears. I have an old Yamaha sub that I will replace soon, and I am using a pioneer vsx-1020k reciever. My question is after I ran the autosetup, i checked all the speaker levels and distances and they seem good. There are numerous audio presets to choose from and I want to know what I should use for watching tv, blu-rays, listening to cds, streaming audio etc. There is also an auto surround mode, direct and pure direct. I don't know what the differences are. The manual explains what these setting do but it does not say in which instance to use them.
Post edited by JOPARE on
  • nguyendot
    nguyendot Posts: 3,594
    edited March 2011
    Auto selects the correct sound decoder and uses that - depending on which signal is coming in.
    Direct and Pure direct don't apply any settings, what comes in, goes out. As little or no processing.
    Main Surround -
  • JOPARE
    JOPARE Posts: 2
    edited March 2011
    So I should pretty much use Auto for everything? What is the purpose of the other settings?
  • HeyJay
    HeyJay Posts: 21
    edited March 2011
    Personal preference :) I have the VSX-32 and use THX Cinema for TV/Movies. Not sure if the 1020 has THX modes
  • nguyendot
    edited March 2011
    It doesn't, I believe the 1120 is the one with THX Select2
    Main Surround -
