CSi400 how High can it go ?
Hello Polks,
Since I got my wdsrn, new location is needed for my csi400. The only way I can think of is to mount it on top near the ceiling, approx 15 ft from the ground. Is this within spec? Other options is to placed on a stand (home built) but it looks funny plus the fireplace is right next to it. I need your IDEAS polks?
Thank you
Thank you
Godspeed,
D0661E
AVR:Pioneer Elite SC-07
Surrounds: RTis
2channel:Rti100 (carver driven
Sub:SVS PB12-Plus/2
Dedicated AMPs:Adcom GFA535, 2xCarver 1.5t, Carver m1.0t
Wsrn:Hitachi ultra vision LCD60, 32XBR400
PowerConditioner: MonsterC HTS5100
PS3, Toshiba HD A2, etc: SonySACD/ Panasonic gears DIVX.
MR3LIGION: Polkaudio; GSXR; E46; Reeftank;
Odyclub; Xsimulator; Sony; Zune; Canon
D0661E
Surrounds: RTis
Sub:SVS PB12-Plus/2
Post edited by doggie750 on
you have 15 ft ceilings in your house? damn thats pretty big. try putting it that high and angleing it down towards the listening position.
y not directly on top of the tv? some pics would help if you can -
15ft up the wall? Oh no!! Why so high? put it on a shelf slightly pointed down just above the tv if you can. if not I would put it on a small stand under the screen slightly pointed up. Some pics would make it easier if poss.
Dave -
You want it as close to your screen as possible. Can you post pic's?
Geez, everybody posting at the same time -
need pics. However, one suggestion would be to go to Lowes and buy a shelf to mount right above/below your tv. They have decorative pieces and should only cost you about $20.
not to beat a dead horse but pics would help.
________________
In all your getting, get understanding.
