Sonicap High, Dayton Low -- Why?
Zaigrith
Zaigrith Posts: 42
edited March 2011 in DIY, Mods & Tweaks
What is the reasoning behind buying a sonicap capacitor at about 5x the price over the dayton and only using it on highs.
Do the lower frequencies have less distortion and therefore need less quality?
HT:
TV: Samsung UN55C8000 | Player: OPPO BDP-95 | Games: Xbox360 / PS3 | Party Music: Squeezebox Duet
Mains: LSi15 | Center: LSiC | Surrounds: LSiFX | Sub: SVS 20-39pci
Pre-Amp: Outlaw 990 | Power-Amp: Outlaw 7700
Cabinet: Salamander Synergy Twin 30 | Speaker Wire: Lowes 12AG w/ monoprice banana plugs
Post edited by Zaigrith on
  • ben62670
    ben62670 Posts: 15,969
    edited March 2011
    The signal travels directly through the high caps. This is where I tell people to spend the extra money. I use the Dayton's on the lows in the shunt positions where it is less critical.
    Ben
  • Face
    Face Posts: 14,340
    edited March 2011
    Budget, space constraints, etc... Generally, shunt caps don't have as significant of an effect on SQ, but it's not always the case.
  • JimAckley
    JimAckley Posts: 1,138
    edited March 2011
    Also, Dayton has higher-value caps available, whereas I'm pretty sure Sonicap doesn't offer any. Ben, Vr3m, and Face would know that fact better than me though.
    - Computer Rig -
    YAΘIN MS-20L, polkaudio RT5
    - Main Rig -
    Pioneer SC-37, Overnight Sensations, Samsung 52" LCD
    - Currently In Progress -
    Curt Campbell's Uluwatu LCR, LMS Ultra Gjallarhorn, JBL W15GTi stereo subs, 2.1 entertainment system for the gf
  • ben62670
    edited March 2011
    Don't bother with the 1% caps from Dayton. They are the same as the 5% which are usualy within 2%. The stock ones are 10-20%. SoniCap's only go up to about 40uf.
    Ben
    F1nut Posts: 51,783
    edited March 2011
    People trying to save a buck. However, Sonicap is a superior shunt cap and I think they are well worth the extra money.
    33uF is the highest listed.
  • ben62670
    edited March 2011
    So Jesse how many XO's have you heard with Dayton's in the shunt position? I am not arguing about using good caps in the shunt position, but the gains are not as prominent as in the series positions. Also the amount of room the SonicCaps take up is much more than the SonicCaps. The Dayton's are an excellent cap for a lot of the crossovers. The Dayton's are mostly the right length and are thinner than most caps. It cost $135 more for the caps in the shunt positions to use SonicCap's over Dayton's in the typical SDA's with 40 and 20uf caps in the shunt positions. I certainly wouldn't talk anyone out of using the SonicCaps if they wanted them, but I do present the options.
    Ben
    F1nut Posts: 51,783
    edited March 2011
    A few. B&W uses Bennic, which are the same as Dayton. Horrid sound.
    I agree that it is not as critical. However, I am not alone my opinion that Sonicap is a better choice.
  • ben62670
    edited March 2011
    SonicCaps couldn't help the B&W sound IMHO, and that is not a fair comparison. Two different speakers.
    Ben
    VR3 Posts: 29,435
    edited March 2011
    I have used Clarity PX a few times and I like them way better than Dayton.
    I have used Dayton a few times previously and was not overly impressed - when used in the high frequencies they hardly bested the stock components.
    YMMV
  • ben62670
    edited March 2011
    Just a curiosity question. Did you use Dayton's and another brand in the shunt position in the same speaker? I also don't care for them too much in the high position. Better than stock for sure, but not as good as SonicCap's.
    Ben
  • Face
    Face Posts: 14,340
    edited March 2011
    I have, I liked MR's much better. :)
  • ben62670
    edited March 2011
    HeHe. Some of the larger value MR's cost more for a set of XO's than most of the gear I have!
    Ben
  • george daniel
    george daniel Posts: 12,096
    edited March 2011
    not to sidetrack--but,,anyone have any experience with the capacitor for the Sacnspeak Revelator Tweeter,,, the other forums/cap comparasions say that the synergy between the revelator and hovland caps are good,,which is what I have,,but I'm thinking sonicaps and maybe a MR on the tweet(Tyler 7u's)
  • Face
    Face Posts: 14,340
    edited March 2011
    I haven't spent much time with anything from the Revelator line, but MR's work well with Illuminators.
    VR3 Posts: 29,435
    edited March 2011
    Hey George,
    My current mod uses the Revelator
    I am throwing a Clarity Cap MR on it
    I will let you know my results
