Is this upgrade worth it?
double d
double d Posts: 23
edited March 2011 in Speakers
Going from Monitor 40's to Monitor 60's? Would I notice a fairly large difference or would the difference be so slight I would have to listen really hard to notice? They would be powered by HK 147. Thanks.
Post edited by double d on
  • packetjones
    packetjones Posts: 1,059
    edited March 2011
    I would say that it would be a pretty substantial jump. Do you have a sub currently?
    Front - RTiA5's
    Rear - RTiA3's
    Center - CSiA4
    Sub - PSW110
  • 67jason
    67jason Posts: 57
    edited March 2011
    The 40s and 50s will sound almost alike, going from the 40s to 60s would be a very noticeable improvement. Stepping up to the 70s would be the best bang for your buck imho. The monitor 70s are almost in a class all their own when compared to the rest of the monitor line. If you are seriously considering the 60s then you are already okay with towers so why not dive into the deep end of the pool and get the 70s....
  • Geoff4rfc
    Geoff4rfc Posts: 2,911
    edited March 2011
    double d wrote: »
    Two sizes up? Heck yeah!! Higher sensitivity, higher power rating, one extra driver. Yes, on paper, I'd call it a substantial jump.
    Don't have the experience with the 60's but own both the 70's and 40's, big difference. 60's should be right there close behind the 70's.
    Set up: 11.2 HT + 2ch
    Cables: Mogami AES from CDP to DAC - AQ McKenzie XLR from DAC to AVP to amp for 2ch, Emotiva XLR's for the rest - Douglasconnection: Furutech Alpha 36 12g speaker wire for 2ch, Furez 10g speaker wire for the rest - AQ Forest48 HDMI for the display, AQ Carbon48 HDMI from BRP to AVP - VR3 filtered power cables for CDP, BRP and AVP, Emotiva power cables for the amps - AudioQuest 707 power conditioner.
  • double d
    double d Posts: 23
    edited March 2011
    Thanks for replies. Yes I have a sub, Bic Acoustech H-100.
    I think the 70's would be too much for my receiver, wouldn't they??
    Planning on a new receiver but may be a year or two down the road.
  • dnoyeB
    dnoyeB Posts: 114
    edited March 2011
    I don't think you need to make that jump. I think the 40s should pair just fine. If your going to floor stander I'd go to the 70s. Not because they would sound any better but because their resell value will probably be significantly higher if you decide to move on.
    The 50s will give you a jump but mostly likely only in volume.
    Music
    LR: Polk Monitor 70 (willing to sell if interested)
    C: Cerwin Vega E-75C
    Sub: HSU VTF-2 MK3
    AVR: Sony STR-DE835
    AMP:
    HT
    5.1: Paradigm CT110
    AVR: Integra DTR-4.6
    WTB: RTiA9 or RTi12
  • slammin86
    slammin86 Posts: 238
    edited March 2011
    I went from the 50's to the 70's and it was a huge jump. Go with the 70's now, if you feel the receiver isn't enough then add an external amp.
    Receiver: ONKYO 709
    Amplifier: Acurus A200x3
    Front: EmpTek E55Ti
    Center: EmpTek E56Ci
    Surround: EmpTek E5Bi
    Sub: Elemental Designs A5-350
    TV: LG 55"
    Blu-Ray: PS3
  • NewHTguy
    NewHTguy Posts: 584
    edited March 2011
    If music matters, the 70s are probably the way to go. But if HT is your thing, then I would definitely you make sure to buy a sub if you don't have one.
    MAIN: Polk Lsi9s; Polk PSW505; Lsic (in box); Onkyo SR-875; Parasound 2250; Cambridge Audio 740C; LG BD370
    OFFICE: Polk Lsi7; REL T3; HK 3490; CA 840W; Onkyo C-S5VL
    BENCHED: CS20; OWM3s
  • Geoff4rfc
    edited March 2011
    double d wrote: »
    The 70's are rated from 20 - 275 watts. If your receiver can push at least 20 watts per channel with all channels driven, you'd have enough power. Granted, more power would make them more dynamic, but there's you answer.
    I love all the extra advice that's thrown your way.
    Best-O-luck with your HT efforts.
  • 67jason
    67jason Posts: 57
    edited March 2011
    double d wrote: »
    im running the 70s my receiver claims to put out 75 watts per channel...which is actually less with all channels driven. The 70s are fine. More power would make them more dynamic, but really they are fine....im runnin 60s too.
  • Dabutcher
    Dabutcher Posts: 2,606
    edited March 2011
    I would go with the Monitor 70's. They are by far the best new monitors by Polk you can buy. Every other week they are on sale at Newegg for 179.00 a piece w free shipping. This is for a speaker that was around 450.00 a pop when it first came out. . Good luck,Darryl
