Blackstone frequency coverage
dnoyeB
dnoyeB Posts: 114
edited March 2011 in Speakers
The low end on these speakers is 115hz. How can you cover the low end with these speakers? 100hz is the typical sub frequency but these don't hit 100! I'm concerned about how to round out the bottom with out needing an extra speaker.
Am I just supposed to accept this when. I get satellites?
Music
LR: Polk Monitor 70 (willing to sell if interested)
C: Cerwin Vega E-75C
Sub: HSU VTF-2 MK3
AVR: Sony STR-DE835
AMP:
HT
5.1: Paradigm CT110
AVR: Integra DTR-4.6
WTB: RTiA9 or RTi12
Post edited by dnoyeB on
  • Polkitup2
    Polkitup2 Posts: 1,642
    edited March 2011
    Yes, but you will wish you had a sub.
  • Topper
    Topper Posts: 403
    edited March 2011
    a good small sub like the Polk PSW111 will have no probs reaching that so you wont have any hole as long as their all properly set up
    EDIT: oops didn't notice that you did not want to use a sub. I think with satellites, its really a prerequisite
  • Matt34
    Matt34 Posts: 318
    edited March 2011
    They are really meant to be ran with a subwoofer of some sort. You will want to place the sub close to the front running a higher crossover like they need. An Epik Legend would be a great choice as it can be crossed-over higher than most other subs due to it's design. 20-200 Hz +/-3.5 dB
  • packetjones
    packetjones Posts: 1,059
    edited March 2011
    Check out this thread about a review. It was very impressive for satellites and a sub.
    http://www.polkaudio.com/forums/showthread.php?t=116751
    Front - RTiA5's
    Rear - RTiA3's
    Center - CSiA4
    Sub - PSW110
  • dnoyeB
    dnoyeB Posts: 114
    edited March 2011
    I actually have a sub and don't mind using a sub. But subs tend to start at 100Hz and go down from there. This leaves some gap between the sub and the satellite. This is what I am concerned about.
    Furthermore, aren't sounds above 100Hz localizable? If so, isin't it a mistake to have satellites that don't drop down to non-localizable frequencies?
    Music
    Sub: HSU VTF-2 MK3
    AVR: Sony STR-DE835
    AMP:
    HT
    5.1: Paradigm CT110
    WTB: RTiA9 or RTi12
  • packetjones
    edited March 2011
    I would listen to them before you start complaining.
    Front - RTiA5's
    Rear - RTiA3's
    Center - CSiA4
    Sub - PSW110
  • Matt34
    Matt34 Posts: 318
    edited March 2011
    dnoyeB wrote: »
    If you place your sub within a couple feet of your left/right speakers and level match it, you reduce the localization of subwoofer.
    Remember crossovers are not brick walls, if you defeat the build in x-over on the sub and run the x-over on your receiver at 100-120hz or whatever is it's highest setting you shouldn't have any significant gaps.
  • Face
    Face Posts: 14,340
    edited March 2011
    FYI, below 120hz is non directional.
  • dnoyeB
    dnoyeB Posts: 114
    edited March 2011
    Face wrote: »
    Thanks. That makes a big difference since the TL3s -3dB drop off is at 115Hz. I found some review of the HSU VTF-2 MK3 showing the -3dB upper point at 121Hz. This makes me feel more comfortable about this combination.
    Music
    Sub: HSU VTF-2 MK3
    AVR: Sony STR-DE835
    AMP:
    HT
    5.1: Paradigm CT110
    WTB: RTiA9 or RTi12
  • BeefJerky
    BeefJerky Posts: 1,320
    edited March 2011
    DSkip wrote: »
    Debatable. I'd put that number more around 50-60 hz
    I'd say about 60-80hz for me. Once over 80hz, it is very obvious to me where the sound is coming from. I'm honestly not sure where the 120hz number came from, but the phrase "from thin air" comes to mind.
    Honestly, it seems like the number varies somewhat from person to person. However, I find it very hard to believe that someone could not localize a sound that is over 90hz.
  • Topper
    Topper Posts: 403
    edited March 2011
    if you place the sub between the speakers, it'l be tough to localize. Don't worry too much about the number - I've played with the TL2s and they are excellent !! properly setup you can barely localize the sub
