ASIO driver..help!
dhart86
I'm currently using PC>HRT streamerII dac>Rotel integrated>LSI7
The USB Dac utilizes asynchronus stream mode.
Would an ASIO driver increase the sound quality to my set-up?
1. What do ASIO driver do?
Main Rig:
Antipodes DX > Roon > PS Audio Directstream Jr.>deHavilland Ultraverve 3 >Belles Reference 150a >Harbeth C7 ES3
Second Rig:
Roon> PS Audio Directstream Jr Bridge II > EE Minimax pre (Tutay mods) >Belles 150A Ref >Monitor 5 (Westmassguy-modded)
Second Rig:
Post edited by dhart86 on
Turntable: Empire 208
Arm: Rega 300
Cart: Shelter 501 III
Phono Pre: dsachs consulting
Digital: Marantz SACD 30n
Pre: Conrad Johnson ET3 SE
Speakers: SDA 2.3TL, heavily modified -
yes, it should be better.
ASIO bypasses the normal audio path from the user application through layers of intermediary Windows operating system software, so that the application connects directly to the sound card hardware. Each layer that is bypassed means a reduction in latency (the delay between an application sending audio information and it being reproduced by the sound card, or input signals from the sound card being available to the application). In this way ASIO offers a relatively simple way of accessing multiple audio inputs and outputs independently. Its main strength lies in its method of bypassing the inherently high latency and poor-quality mixing and sample rate conversion of Windows audio mixing kernels (KMixer), allowing direct, high speed communication with audio hardware. Unlike KMixer, an unmixed ASIO output is "bit identical" or "bit transparent", that is, the bits sent to the sound card are identical to those of the original source, thus having higher audio fidelity.
What operating system are you using?
+1. Assuming your hardware supports ASIO, it is the way to go. Also, Winamp's kernel streaming plugin does the same thing.Dali Optikon 1Mk2
NAD D3020 V2
Schiit Bifrost 2/64
..the rest are headphone setups. -
Windows XPMain Rig:
Second Rig:
Roon> PS Audio Directstream Jr Bridge II > EE Minimax pre (Tutay mods) >Belles 150A Ref >Monitor 5 (Westmassguy-modded) -
Thanks for the info...............How does one obtain ASIO drivers?Main Rig:
Second Rig:
My brother and a couple others use the HRT with Windows XP..............maybe they will chime in.
What did a Google search bring up? It's not that difficult, plus the HRT streamer has all kinds of activity on the 'net. Get your read on.
What program are you running for audio? Media Monkey, WINAMP, Foobar, etc? Usually you start by searching for an ASIO driver for your specific audio player.
I was going to post that too, but I didn't have enough info at the time.
Thanks 4 info H9 & Face
I run media monkey, is asio4all good for media monkey
Thank you guys for all your help,
Hey Face you modded a pair of Lsi7's for me (nice work) would you be interested in modding another pair for me in a month or so?Main Rig:
Second Rig:
Keep in mind if you end up moving on to Windows 7 you don't necessarily need ASIO since WASAPI is a total rewrite (due to the aged audio subsystem in XP) and offers an exclusive mode for audio output.
A simple google of ASIO vs WASAPI will give you lots to read about. -
thanks for the heads up jinjukuMain Rig:
Second Rig:
PM sent."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
