ASIO driver..help!
dhart86
dhart86 Posts: 1,594
edited March 2011 in 2 Channel Audio
I'm currently using PC>HRT streamerII dac>Rotel integrated>LSI7
The USB Dac utilizes asynchronus stream mode.
Would an ASIO driver increase the sound quality to my set-up?
1. What do ASIO driver do?
Main Rig:
Antipodes DX > Roon > PS Audio Directstream Jr.>deHavilland Ultraverve 3 >Belles Reference 150a >Harbeth C7 ES3
Second Rig:
Roon> PS Audio Directstream Jr Bridge II > EE Minimax pre (Tutay mods) >Belles 150A Ref >Monitor 5 (Westmassguy-modded)
Post edited by dhart86 on
  • quadzilla
    quadzilla Posts: 1,543
    edited March 2011
    First answer, unknown.
    Second answer, http://en.wikipedia.org/wiki/Audio_Stream_Input/Output
    Turntable: Empire 208
    Arm: Rega 300
    Cart: Shelter 501 III
    Phono Pre: dsachs consulting
    Digital: Marantz SACD 30n
    Pre: Conrad Johnson ET3 SE
    heiney9 Posts: 25,396
    edited March 2011
    yes, it should be better.
    ASIO bypasses the normal audio path from the user application through layers of intermediary Windows operating system software, so that the application connects directly to the sound card hardware. Each layer that is bypassed means a reduction in latency (the delay between an application sending audio information and it being reproduced by the sound card, or input signals from the sound card being available to the application). In this way ASIO offers a relatively simple way of accessing multiple audio inputs and outputs independently. Its main strength lies in its method of bypassing the inherently high latency and poor-quality mixing and sample rate conversion of Windows audio mixing kernels (KMixer), allowing direct, high speed communication with audio hardware. Unlike KMixer, an unmixed ASIO output is "bit identical" or "bit transparent", that is, the bits sent to the sound card are identical to those of the original source, thus having higher audio fidelity.
    What operating system are you using?
  • PrazVT
    PrazVT Posts: 1,607
    edited March 2011
    +1. Assuming your hardware supports ASIO, it is the way to go. Also, Winamp's kernel streaming plugin does the same thing.
    Dali Optikon 1Mk2
    NAD D3020 V2
    Schiit Bifrost 2/64
    ..the rest are headphone setups.
  • dhart86
    edited March 2011
    heiney9 wrote: »
    Windows XP
    Main Rig:
    Second Rig:
  • dhart86
    edited March 2011
    Thanks for the info...............How does one obtain ASIO drivers?
    Main Rig:
    Second Rig:
    edited March 2011
    My brother and a couple others use the HRT with Windows XP..............maybe they will chime in.
    What did a Google search bring up? It's not that difficult, plus the HRT streamer has all kinds of activity on the 'net. Get your read on.
    edited March 2011
    What program are you running for audio? Media Monkey, WINAMP, Foobar, etc? Usually you start by searching for an ASIO driver for your specific audio player.
  • Face
    Face Posts: 14,340
    edited March 2011
    edited March 2011
    Face wrote: »
    I was going to post that too, but I didn't have enough info at the time.
  • dhart86
    edited March 2011
    heiney9 wrote: »
    Thanks 4 info H9 & Face
    I run media monkey, is asio4all good for media monkey
    Thank you guys for all your help,
    Hey Face you modded a pair of Lsi7's for me (nice work) would you be interested in modding another pair for me in a month or so?
    Main Rig:
    Second Rig:
  • jinjuku
    jinjuku Posts: 1,523
    edited March 2011
    Keep in mind if you end up moving on to Windows 7 you don't necessarily need ASIO since WASAPI is a total rewrite (due to the aged audio subsystem in XP) and offers an exclusive mode for audio output.
    A simple google of ASIO vs WASAPI will give you lots to read about.
  • dhart86
    edited March 2011
    thanks for the heads up jinjuku
    Main Rig:
    Second Rig:
  • Face
    Face Posts: 14,340
    edited March 2011
    PM sent.
