Best Solder Station
AudioGenics
best solder station for the money ?
Post edited by AudioGenics on
http://www.parts-express.com/pe/showdetl.cfm?Partnumber=374-100
I have a few, and I gave some away to friends. Never had an issue. Works great.
Ben -
http://www.amazon.com/Weller-WES51-Analog-Soldering-Station/dp/B000BRC2XU/ref=sr_1_1?ie=UTF8&qid=1291080036&sr=8-1
One of the best investments I've made in this hobby."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
Surface mount or through hole ? For surface mount Met Cal makes a decent unit that will do through hole as well. If its for general type stuff and through hole, I've had good luck with the Weller's. Make sure you get one with adjustable temperature. :cool:
+1 for the Weller... mine is the same model as being sold on Amazon, and it is well balanced and precise. It heats up quiclky and has an adjustable temp cotrol. I love it.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon 680d DSD
OMG !
Metcal Soldering Station, MX-5000 Series
by OK INTL / METCAL
Price: $1,010.00
I appreciate the suggestion
and the Weller is really nice too
but for $10.00 and another $4.95 for extra tips I'm ordering the Stahl.
THANKS Ben62670
Left my Weller Station at my parents home.
I got a Cooper iron on a weller cast stand with a homemade controller. -
You will be very happy with it. Mine is running right now doing a set of XO's.Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
I have a Weller gun (great for the grunt work) and a Radio Shack pen.
I've lusted after the Weller station for some time but at that price (and the endorsement of Ben) the Stahl looks like my next purchase.Sounds good to me... -
AudioGenics wrote: »OMG !
by OK INTL / METCAL
Price: $1,010.00
THANKS Ben62670
The Met Cal is what we used at 5601 Metro Drive. Like I said mainly for SMA and very delicate soldering. As far as the price it was on Matthew Polk's dime.
Sorry but it did spoil me. The weller is what I use at home and works well for a variety of applications. :cool: -
Taking the price into consideration, the Stahl's a good unit. The tip has fallen out of mine after using it for a full morning, our dining room table is now antiqued. The cord from the iron to the base is captive, and gets difficult to get the twists out. For $10 bucks I can deal with that.
If I were looking to buy one without the thought of replacing it in a year or so, I'd go with the Weller Face linked to.Wristwatch--->Crisco -
Agreed, although I like the digital model. Excellent unit, either way.
Weller is the name you want on your work desk and I paid around $65 for mine.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint. -
The tips do need to be snugged up pretty tight. After a few heat cool cycles the tip hasn't loosened in a long time. The tips are very nice and have some mass to them. That is very helpful when doing a large joint, or tinning a heavy connector.
Ben -
Yep, I'd never go for anything else than a weller (I've been spoiled, I admit :cool:)!Agreed, although I like the digital model. Excellent unit, either way.
Unless one can afford a PACE Soldering station http://www.paceworldwide.com/# you might as well stick wit Weller
DARE TO SOAR:
Weller. I've been using them for years with no major issues. I've had to replace the cords, heating elements, and tips, but all the Wellers fit your finger grip, don't overheat your fingers, and work.
I worked a bench for years and it's all I'd ever use.
I've got a drawer full of off brand soldering irons I've bought over the years that just don't get used because they're uncomfortable to use and awkward.
ECG has a nice 20w iron that heats up in a few seconds and heats to about 650 degrees that's nice for a "road box" iron. They're cheap.
I'm going to order the Stahl just to check it out. Looks very good for the $$. -
Hey, you sure can Karma them my way! I'd love to participate in cleaning up that drawer with you. You can thank me laterI've got a drawer full of off brand soldering irons I've bought over the years that just don't get used because they're uncomfortable to use and awkward.
DARE TO SOAR:
Rev. Hayes wrote: »I have a Weller gun (great for the grunt work) and a Radio Shack pen.
Don't let Doro see the "I have . . . Radio Shack pen" part of your post :biggrin:VTL ST50 w/mods / RCA6L6GC / TlfnknECC801S
Conrad Johnson PV-5 w/mods
MF x-DAC V8, HAInfo NG27
NAD SS rigs w/mods
GIK panels -
I have a basic Hakko solder station and Im very happy with it.Its a well known brand in the electronics industry, possibly a little bit more expensive than Weller.Weller is also a good brand.
Fatpiggy -
I got this one last summer, and am very happy with it.
http://www.amazon.com/Hakko-Soldering-Station-936-Iron/dp/B000ARU9HWSunfire Theater Grand IV
SRS 2.1TL
SDA 2BTL's
CSiA6
FXiA4
FXiA6
SDA 2A's
Monitor 10A's
http://www.douglasconnection.com -
^^^^^^Yes^^^^^^+1
Great Bang for the buck. Been using these Hakkos' professionally for 15+ years. Got one at work and one at home. -
I would vote for the Hakko.
Here is an Aoyue 937 digital unit that will work with Hakko tip's.
http://www.amazon.com/Aoyue-937-Digital-Soldering-Station/dp/B000I30QBW/ref=sr_1_2?ie=UTF8&qid=1291396375&sr=8-2
Can't speak personally to this Iron, just wanted to point it out. You will have to use the Amazon review section to make up your own mind. -
Sorry for the thread revive, but I was wondering what you guys thought about this Stahl TCSS station.
http://www.parts-express.com/pe/showdetl.cfm?Partnumber=374-200- Computer Rig -
YAΘIN MS-20L, polkaudio RT5
- Main Rig -
Pioneer SC-37, Overnight Sensations, Samsung 52" LCD
- Currently In Progress -
Curt Campbell's Uluwatu LCR, LMS Ultra Gjallarhorn, JBL W15GTi stereo subs, 2.1 entertainment system for the gf -
for the price looks good when my 20.00 dies may step up if still on sale, but then again the one Ben recommended works GREAT
I don't think there is a better "bang for the buck" soldering station as that one, and they are in stock again FYI. PE sometimes runs out of these and for good reason!!
Stahl Tools SSVT Variable Temperature Soldering Station -
I bought one on Ben's advice and I love it.Testing
Testing
Testing -
Weller.Political Correctness'.........defined
President of Club Polk -
"Have A Little Faith! And Everything You'll Face, Will Jump From Out Right On Into Place! Yeah! Take A Little Time! And Everything You'll Find, Will Move From Gloom Right On Into Shine!"- Arthur Lee -
For potential solder slingers, maybe this would be a good place for this...
http://www.youtube.com/watch?v=I_NU2ruzyc4%26feature=related
Do yourself a favor and take the time to watch it!
On my home bench, I use and love a Hakko station and a Pace desoldering station.
CJA so called science type proudly says... "I do realize that I would fool myself all the time, about listening conclusions and many other observations, if I did listen before buying. That’s why I don’t, I bought all of my current gear based on technical parameters alone, such as specs and measurements."
More amazing Internet Science Pink Panther wisdom..."My DAC has since been upgraded from Mark Levinson to Topping." -
"IF you can shoot pool you can use a broomstick"
Learn how to use the iron before digging into good gear.
Yea, you know who I'm referring to! -
CJ
Thanks for posting that video.
I did learn something tonight. I'll rewatch that again later when I do some more soldering on a board or something.Most people just listen to music and watch movies. I EXPERIENCE them.
Just got my Weller WES-51 Soldering Station the other day, along with an assortment of tips. It did not come with a sponge, damn it!!! Oh well, time to break out the cutters and make a specialized sponge that will fit the tray.Statistics show that 98% of us will die at some point in our lifetime.
The other 2% will work for WalMart. -
CJ
Did anyone notice that the author of that video was using a Weller for the soldering and the (c)rust formed soldering pen was a radio shack pen?
Cant wait for the flux to arrive before I start to use my Weller station!Statistics show that 98% of us will die at some point in our lifetime.
