RTIa7 banana plugs question
bigronnie
bigronnie Posts: 4
Hello everyone,
I'm pretty excited to finally hook up some RTiA7 speakers to my system, but I'm unsure about whether or not they accept banana plugs. The user manual states that only "US" speakers support the plugs. What about Canada, though? I'm used to being lumped in with the US and am wondering if "US" means Canada in this case. I don't want to try prying off posts if my speakers don't in fact support banana plugs.
Thanks for any info.
Ron, Halifax, Canada.
Post edited by bigronnie on
  • ben62670
    ben62670 Posts: 15,969
    edited March 2011
    Just pop the little plastic caps out of the jacks.
    Welcome to Club Polk
    Ben
  • bigronnie
    bigronnie Posts: 4
    edited March 2011
    Thanks! Just wanted to check before prying parts off my new speakers.
  • ben62670
    edited March 2011
    No problem.
    Enjoy!
    Ben
    F1nut Posts: 51,767
    edited March 2011
    I find it easier to unscrew the posts, the plugs will fall out.
  • bigronnie
    bigronnie Posts: 4
    edited March 2011
    Do you mean you prefer to use the posts as opposed to using banana plugs? (Sorry if that's a stupid question)
  • punk-roc
    punk-roc Posts: 1,150
    edited March 2011
    rather than pry the caps off the binding posts (to reveal the banana plug), you can just unscrew the binding posts all the way off (like if you were attaching bare speaker wire). the little caps will fall off if you unscrew the binding posts
    Jason
    2-Channel - So far...
    Pre: Dodd ELP
    DAC: W4S-Dac2
    Source(s): Computer and Denon 2910
    Amp: Parasound HCA-1200II
    Speakers: LSi9s - Vr3 Fortress Mod
    F1nut Posts: 51,767
    edited March 2011
    bigronnie wrote: »
    No, I was referring to removing the plastic plugs. The same thing punk-roc explained.
    As for terminations, banana plugs are the only way to fly, IMO.
  • bigronnie
    bigronnie Posts: 4
    edited March 2011
    Got it!
    Thanks again, guys. Much appreciated.
