Cardas Crosslink speaker cable?
outlander
Does anyone have experience with the Cardas Crosslink speaker cables? If you have heard them I would love to know what your impression was. I?m considering replacing my MIT Terminator 2 with a pair of the Cardas. I know Cardas makes much better cables than the Crosslinks but my budget is only around $200.
Thank you,
O
Thank you,
O
Post edited by outlander on
It's great budget cable. Audio Advisor has a custom Crosslink with 6 conductors per cable instead of the regular 3. It's worth a look.
http://www.audioadvisor.com/prodinfo.asp?number=CR6XCLSP%20%208PSPSP
