Wall Mount for CSI A6
BtrSound
BtrSound Posts: 123
edited March 2011 in Speakers
Does anyone know of any good wall mounts for a CSI A6. The thing weighs 29lbs, so it must be sturdy. I am about to have one custom made from a machinist shop, but it is obviously more costly than simply ordering one online. Any suggestions would be greatly appreciated.
Post edited by BtrSound on
  • bklynNupe
    bklynNupe Posts: 728
    edited February 2011
    I have solid walls, so I simply used heavy duty 2 1/2 inch flat headed screws and left just enough space to slip through the key hole. They worked perfectly and cost me about 3 bucks. I certainly wouldn't recommend this for sheetrock and I'm sure others will chime in with proper wall mounts specifically made for this type of speaker.
    emotiva xpa-2
    emotiva xpa-3
    Denon 3312ci
    Rtia9 /csia6 / FXi A6
    Samsung LN46A650
    SVS PB-12-NSD sub
    Audio Research SP-9 MKIII (GNSC mods)
    W4S ST250
    Lsi 9 (mods)
    W4S DAC-2
    Mac Mini
    Audio Aero Prima CD player
    Pro-Ject debut
  • BtrSound
    BtrSound Posts: 123
    i will be mounting it to the studs, but would still like something sturdy. ia also have a 2 year old, and do not want him pulling that monster down on him.
  • xj4094dg
    xj4094dg Posts: 1,158
    "The good thing about science is that it's true whether or not you believe in it." Neil deGrasse Tyson.
  • BtrSound
    BtrSound Posts: 123
    edited March 2011
    I have thought about those, but it says they are king of flimsy in the reviews, and it makes me nervous just having them sitting on there with a two year old in the house. I think I am going to have custom brackets made.
  • codyc1ark
    codyc1ark Posts: 2,533
    edited March 2011
    I've been considering doing this lately as well with my 5. I'd just go to Lowes or any local hardware store, pick up three 12" 'L' shaped brackets, and then cut a piece of plywood, MDF, whatever you have laying around for it. Three may be overkill, I'm sure if you mount them into your studs that two would be enough. Just scuff them up, and paint them to match!
  • jbooker82
    jbooker82 Posts: 1,627
    edited March 2011
    AVR: Onkyo Tx-NR808
    Rear: FXI A4
    Sub: Polk DSW Pro 660wi
    TV: LG Infinia 50PX950 3D
    IC: AudioQuest Black Mamba II
  • larry777
    larry777 Posts: 480
    edited March 2011
    If you don't want to see the brackets, just screw in a 2 x 4 cut to the proper length crossways into your wall studs. Paint it Black. Then screw 2 Heavy Duty Bolts into this 2 x 4 ...the proper distance apart.....and mount your center to them using the back bracket. You could even put some duct tape on these bolt heads to prevent scratching your speaker bracket. That should hold it just fine....and dosn't cost much. You won't even notice the 2 x 4.
    Home Theatre.............
    Pioneer SC-35
    Polk RTi10's Fronts
    Polk CSiA6 Center
    RTi4 Surrounds
    SVS PB-12 Sub
    2 Channel.............................
    Yaqin MC-100B
    Energy RC-70 Speakers
    Arcam CD-192 Disc Player
    Van Den Hul Interconnects
  • Erik Tracy
    Erik Tracy Posts: 4,673
    edited March 2011
    BtrSound wrote: »
    I use these for my CSi3 center - it ain't flimsy.
