: Coaxial Digital Connection Vs Digital Fiber Optical Connection?
PolkClyde
PolkClyde Posts: 662
Which has the better sound quality,which one should I throw away.thanks
PolkAudioClyde
Post edited by PolkClyde on
  • thsmith
    thsmith Posts: 6,082
    edited February 2011
    I found Coaxial to sound best YMMV
    Highly recommend the Kimber Kable D-60
  • jinjuku
    jinjuku Posts: 1,523
    PolkClyde wrote: »
    I doubt you could tell the difference. Try each one. I like TOSLink due to zero potential of ground differential. Some will say the signal will have to go through emitter up/down conversion. I have never heard an instance where it is an audible problem.
    heiney9 Posts: 25,401
    Toslink has an extra conversion and you have to decide on glass or plastic for the optics. Glass is prefered but it can cost more.
    If you go coax be sure it's a true 75 ohm cable.
    I use both and prefer a nice 75 ohm coax. I currently use Signal Cable.
  • nspindel
    nspindel Posts: 5,343
    Ditto on Signal.
  • steveinaz
    steveinaz Posts: 19,545
    It depends on the quality of your interfaces. With good interfaces and a good digital cable, I have found Toslink to be the most neutral; coaxial sweetens the deal a little bit if you don't care for a sterile presentation. If you go toslink, buy a quartz glass cable--not plastic fiber.
    Toslink is real good for connecting to a cable box or sat box as they tend to be noisy--and can introduce hum.
  • zingo
    zingo Posts: 11,258
    I prefer digital coax unless I specifically need the electrical isolation provided by Toslink and mentioned about. The best performance for the dollar coax I've found is DH Labs D-75. It's a great design using Teflon and silver over copper conductors, and is true 75 ohm from cable to connectors.
  • steveinaz
    The DH Labs D-75, Belden 1694A, and Signal Cable coax are all real good budget digital cables, IMO.
  • TNRabbit
    TNRabbit Posts: 2,168
    The digital cable will pass slightly higher resolution audio than the optical, if you're listening to multichannel/HD.
    TNRabbit
    NO Polk Audio Equipment :eek:
    Sunfire TG-IV
    Ashly 1001 Active Crossover
    Rane PEQ-15 Parametric Equalizers x 2
    Sunfire Cinema Grand Signature Seven
    Carver AL-III Speakers
    Klipsch RT-12d Subwoofer
  • WilliamM2
    WilliamM2 Posts: 4,804
    TNRabbit wrote: »
    HD audio only passes over HDMI or analog. Optical and coax will both pass the same resolution/formats.
  • samnor
    samnor Posts: 155
    WilliamM2 wrote: »
    can you clarify "hd audio"? coax and optical do 5.1...are you referring to 7.1?
    Fronts: Wharfedale diamond 9.6
    Sub: Wharfedale sw250
    Rears: Wharfedale diamond 9.1
    Center: Paradigm cc-350
    Pre-amp: Oppo dv981hd
    Amp for fronts: Parasound hca-1500a
    Amp for rears: Adcom gfa-5400
    Amp for center: Marantz MA500 monoblock
    Polk multimedia speakers for PC setup
  • headrott
    headrott Posts: 5,496
    I also prefer the the coax over toslink. In fact, I did not even install a toslink jack in the DAC I am building. As others have stated, true 75 ohm cable is important, but a true 75 ohm jack is just as important. I prefer using the Eichmann PhonoPod RCA Socket. Excellent construction, and true 75 ohm.
    Greg
  • jinjuku
    samnor wrote: »
    DTS and Dolby digital are the 5.1 lossy formats being referred to.
    As an example:
    DTS Digital Surround, also known as the "Core", is the high-quality standard for providing 5.1 channels of discrete digital audio in consumer products. With the ability to operate at 44.1 or 48kHz, and at a bit rate of upto 1.5Mbps
    One goal of the DTS-HD Master Audio format was to allow a bit-to-bit representation of the original movie's studio master soundtrack. To accomplish this, DTS-HD MA supports variable bit rates up to 24.5 Mbit/s on a Blu-ray Disc and up to 18.0 Mbit/s for HD DVD. The format supports a maximum of 192 kHz sampling frequency and 24-bit depth samples in 2 channels stereo mode, and 96 kHz/24bit resolution in multichannel mode with up to 8 channels.
    S/PDIF and TOSLink don't have the bandwidth for the HD audio formats.
  • thuffman03
    thuffman03 Posts: 1,325
    I go with coax only because it generally cost less than an optical cable. Though I have used both I cannot hear any real difference. Guess my ears might not be as good as others.
    Sunfire TGP, Sunfire Cinema Grand, Sunfire 300~2 (2), Sunfire True Sub (2),Carver ALS Platinum, Carver AL III, TFM-55, C-19, C-9, TX-8, SDA-490t, SDA-390t
  • nguyendot
    nguyendot Posts: 3,594
    TNRabbit wrote: »
    I'd like you to elaborate on this one.... I think you're mistaken.
    They pass identical signals.
    Main Surround -
  • ben62670
    ben62670 Posts: 15,969
    I use COAX and never heard any noise caused by the electrical connection.
    Ben
  • acmf74
    acmf74 Posts: 937
    I personally use Blue Jeans Belden 1694A for my Cable box and BR player. I also don't hear any interference from usisng these cables.
