Will a 3 Channel amp suffice for a Home Theater setup?
stangjason
stangjason Posts: 341
edited February 2011 in Electronics
I've been shopping for budget 5 channel amps for around $200, a lot of older ones, and I've decided that I may be better off buying a good 3 channel amp instead. Will I be messing up my sound by running my rear speakers off of my receiver and my fronts off of a different amplifier?
All I really want is a bit more power to bring out the voices a little more during movies and to have the power to enjoy music on occasion. I suppose you could say I miss my H/K 635's musical capabilities plus it was a little less harsh at times during TV programs but my Pio 1120 does blow the H/K away when it comes to dvd/bluray movies.
Pioneer vsx-1120k, B&K Sonata series video-5 amplifier, Polk Rti8, Fxi3, Csi5, and HSU VTF-1
Post edited by stangjason on
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    You will be fine, run the 3 channel amp for the front / center and then run the rear surrounds off the AVR.
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
    tonyb Posts: 33,068
    Yep,what Steve said.
    I know I said it before, but it's worth a mention again. If your missing the musicality, try swapping out cables,makes a world of difference.
  • stangjason
    tonyb wrote: »
    What cables do you mean? Speaker cables?
    With exception of HDMI cables I am using the same ones as I did with the H/K Receiver.
  • nguyendot
    nguyendot Posts: 3,594
    I run an Adcom 2535 with 2 channels bridged for my center channel and am pretty happy with it.
    Main Surround -
  • stangjason
    nguyendot wrote: »
    Yeah that's about the only one I'm aware of at this moment. The one thing that bothers me about it is that my center channel will have a lot more power than my fronts but in a way that's probably what I might want plus the 60 watt power rating even though I know it's underrated and a lot more than the 50watts my Pioneer lab tested at (can anyone clear this up for me?).
  • nguyendot
    Oh it puts out plenty of power, even at 60w. The center channel takes the most beating in home theater, and more power to it is always a good thing.
    Main Surround -
  • PrazVT
    PrazVT Posts: 1,607
    Would agree. I was using a Parasound 2250 for my surrounds for a while and this week, switched back to letting my receiver power the surrounds. Not hearing any difference really, with movies / tv.
    3 ch is a good idea - esp for your stated budget.
    Dali Optikon 1Mk2
    NAD D3020 V2
    Schiit Bifrost 2/64
    ..the rest are headphone setups.
  • Sherardp
    Sherardp Posts: 8,038
    I used to run 3 Outlaw M2200 monoblocks on my front end. Nice amps for sure if your looking, but as said earlier you will be fine. I eventually went to a 5 channel amp + my D-Sonic 1000S 2 channel amp for my fronts. A tad overkill but I love having it.
  • stangjason
    Can two of these Adcom 2535 be bridged into a 5 channel amp?
  • cheddar
    cheddar Posts: 2,390
    I've found that most movie surround tracks just don't use the other speakers enough to appreciate an audible difference with surround amplification. They usually get 1/10th of the power going to the front three with most effects. That's probably less than 5 watts per channel even at moderately loud volumes for most if not all of the movie.
  • cfrizz
    cfrizz Posts: 13,415
    They make a huge difference with SACDs and DVD-As Cheddar. After I moved, for a short time it took awhile for me to get my surrounds up and when I put in TDSOTM, I had to stop it & not play it until I got my surrounds hooked up.
    But also, the speakers also benefitted from being hooked up to my Sunfire amp. I am able to more clearly hear the back channels with it, rather than when I just had them hoooked up to my old receiver. I swear the amps in receivers aren't worth crap.
  • cheddar
    Yes, I'd agree that with any good music surround track, especially high resolution like SACD or DVD-As (blu-ray lossless music too), surrounds get a much better workout than with most movie tracks.
  • stangjason
    cfrizz wrote: »
    Are you saying I should use an amp on my rear speakers? My rear speakers are pretty useless for music, as far as I'm aware, because they are dipole/bipole. I put my speakers into stereo mode for music most of the time but 5 speaker stereo doesn't sound all too bad either and sort of adds an interesting effect to music to me.
  • ROHfan
    ROHfan Posts: 1,014
    tonyb wrote: »
    Swapping cables makes that much of a difference to not need to add an external amp for musicality? Because if cables give better musicality then I may not need an avr with preouts and an external amp. That will save a lot of cash.
    TV: 65" Samsung QLED 4K
    AIYIMA Tube T7 preamp --- Nobsound 12AX7 tube preamplifier
  • cfrizz
    stangjason wrote: »
    Yes, the rear speakers sound just as good as the front speakers do with seperate amplification. Everyone gives them the short end of the stick, but mine really came alive when I hooked them up to my amp, we both have FXi3s. All my music is played in DTSII mode for music and the Sunfire does a very good job of sending even 2 channel music to all of my speakers.
