MM465 too loud..!
Systems
Systems Posts: 14,872
edited February 2002 in Car Audio & Electronics
Hello,
I'm having difficulty with my MM465. I have hooked them up to my RF500.2 and my tweeters begin to distort at a sound level of 25 of my radio. The gain is opened at 1/3, the x-overs are turned as low as they can get (0Db) and my radio is filtering at 80Hz (i have had it higher but it didn't work). Am i giving them too much power, or do I already have a hearing problem???
Thanx...
Testing
Testing
Testing
  • wervisser
    wervisser Posts: 2
    I own a Pioneer DEH-P9100R head unit. I don't know exactly what you mean with 'how is your volume scaled', but if it is what I think it is.... I have turned my radio volume to 25 with a maximum of 40, so it's playing at half of its 'capacity'.
    I will try to turn my gain to 1/2 and listen to it if it is working. Otherwise I will let you know. Thanks for your quick reply!
    Sincerely Werner.
    Sincerely,
    Werner Visser
