Mike
Bamboobiscuit
Hi I'm new to this and I have a question on hooking up my system I have a Nakamichi SR-3A amplifier/receiver with 2 Jamo C605 speakers I want to add a polk audio PSW10 subwoofer is it ok to hook up the Jamos to the "A" channel and the Polk Sub to the "B" channel? I am thinking this will let me turn the sub on and off by switching from "A" to "A" and "B" will this work? Thanks.
Post edited by Bamboobiscuit on
I assume you're talking speaker selector switch here... yes?
If yes, then yes... but you will not be integrating the sub with your speakers, if you go the A+B route.
Welcome to Club Polk...
EDIT: You may want to choose a more descriptive title in the future. Who is Mike? And are bamboo bisquits any good?
More later,
Tour...
Vox Copuli
Bamboobisicuits are delicious:) I am Mike this is my first foray into the forums so this out to be fun.Thank you for your reply I appreciate the help. I understand the sub wont be integrated what I am wanting is the ability to turn off the sub and run the Jamos alone at times the C605s are pretty good but I listen to alot of different music and I like a little more bass sometimes I just wanted to make sure I wouldn't fry anything before I went and did it. Again I say thank you and I'm sure I'll have more questions in the near future. Thank you for the welcome!
