Difference between digital rca cable and analog rca cable
EDUBAG
Hello guys,
this subject comes from a discussion i held with my stepfather last saturday while listening to some tunes in my place.
He brought me a digital cable, rca to rca so i could hook up my subwoofer. I told him that that is not a sub cable and they were made for digital transfers, he loughed his a.. Off and said that it is the same since they are coaxial cables.
I have been wondering about these anyways since i do not use any digital output (except hdmi), i am a little bit familiar with optical cables but do not know about the digital coaxial.
Please shime in.
Eduardo
Please shime in.
Eduardo
HT:
POLK AUDIO RTI4 FRONTS
CSI3 CENTER
DEF TECH PROMONITOR800 SURROUNDS
PSW 125 SUB
PIONEER ELITE AVR23TXH AVR
APPLE TV 160GB
PANASONIC BLURAY PLAYER
50" PANASONIC PLASMA TCP50C2
2 CHANNEL:
KEF R300 THREE WAY BOOKSHELF GLOSS PIANO BLACK
ROTEL RC 990BX PRE
ROTEL RB 990BX AMP
OPPO DV980 (AS CD PLAYER)
PIONEER PL100 TURNTABLE WITH SHURE MX97E CART
MIT EXP2 SPEAKER CABLES
CSI3 CENTER
PSW 125 SUB
APPLE TV 160GB
2 CHANNEL:
ROTEL RC 990BX PRE
ROTEL RB 990BX AMP
Post edited by EDUBAG on
While it's possible to optimize a cable for one our the other, they're both 75 ohm cable. Check the description on these: http://www.monoprice.com/products/subdepartment.asp?c_id=102&cp_id=10236
Not a recommendation, just an example. -
In other words, it doesn't need to say, "subwoofer cable" on the package in order to transfer a subwoofer signal. And, I'm just going to throw this out there - while I believe that cables matter, I believe this one matters least.
The 75ohm specification (correct connectors, shielding, topology) is more closely followed with good digital cables. Analog RCA's are all over the map; some have no shielding, don't use RG-59 or RG-6 (coaxial) topology, etc.
Any digital cable can be used as an analog cable, but not all analog cables work well for digital.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2 -
^^^ Yes, I didn't mean to imply I'd use analog ICs for subwoofer connection. Thanks Steve!
A digital or analog RCA would be fine for a subwoofer input cable. It's just more important to use a digital cable (properly spec'd) for digital connections.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
mdaudioguy wrote: »^^^ Yes, I didn't mean to imply I'd use analog ICs for subwoofer connection. Thanks Steve!
Yes, a subwoofer signal IS analog... Doh! :redface:
So.... What Steve said. :biggrin: -
Yep/The 75ohm specification (correct connectors, shielding, topology) is more closely followed with good digital cables. Analog RCA's are all over the map; some have no shielding, don't use RG-59 or RG-6 (coaxial) topology, etc. -
this is good it answers my question that i had in my thread .....thanks everyoneBudget 5.1 H.T. Set UpHK avr 247 - Adcom GFA-7605
- Belkin PF60 Power Conditioner - Cs2 center channel - Monitor 60's fronts - Monitor 30's rears
Mirage Bps 150i powered sub - 40"Samsung LCD ln40c530 - Sony Blu Ray Player BDP-S370 - Comcast digital hd box(motorola dcx3400)
Monoprice Premium Interconnects Monoprice Ultra Slim HDMI w/Redmere
-Knukonceptz Kord 10 Gauge Speaker Wire - Nakamichi Banana Plugs
Custom Jumpers
