Cable burn-in
acmf74
acmf74 Posts: 937
Can I burn in a pair of cables connected to a CD player that aren't attached to a AMP/AVR? Essentially I want to have the CDP play for a few days but the other side of the cables aren't plugged into anything.
Thanks,
Post edited by acmf74 on
  • ohskigod
    ohskigod Posts: 6,505
    edited February 2011
    I kno that works for burning in a CDP, most don't matter, but my Jolida sounded like @ss out of the box for some reason. left it on constant play for 3 days straight with no amp or whatnot, came back and it sounded better.
    wether that also works for the cable itself? I never heard cable burn in make a difference so I couldnt be certain, though signal is going through it so i assume it does the same as if it is hooked up to a reciever, but not 100 percent sure.
    Living Room 2 Channel -
    Upstairs 2 Channel Rig -
  • quadzilla
    quadzilla Posts: 1,543
    The point of "burning in" a cable is to charge the dielectric to the point that the energy it absorbs and discharges during signal transfer reaches a minimum.
    Would signal pass through the cable? I'd think the CDP would see essentially infinite resistance, and so no signal would pass.
    Turntable: Empire 208
    Arm: Rega 300
    Cart: Shelter 501 III
    Phono Pre: dsachs consulting
    Digital: Marantz SACD 30n
    Pre: Conrad Johnson ET3 SE
  • NotaSuv
    NotaSuv Posts: 3,871
    I believe there a just a few posts about the same........
