Audyssey DSX
sockeye
Denon 4310 on the way. Any first hand knowledge? Is Audyssey front wides better than Dolby surround rears, or heights?
Post edited by sockeye on
RTiA7 front
CSiA6 center
RTiA3 wide, height
RC85i surround enclosure
RC80i rear surround enclosure
DSW Pro660wi -
Depends on your placement. If your mains are correctly placed, the wides can help fill in the gap between the mains and side surrounds. Personally, my mains are spaced out pretty wide because of my projector screen, so I don't need the DSX width channels. I do, however, run DSX heights in my 9.2 setup.
I know Audyssey says that the width channels should take priority over rear surrounds... but honestly, if you have the space to place them well, rear surrounds do more to recreate the theatrical sound than DSX width/height does. I would ditch my height channels before I ever gave up my rear surrounds.Equipment list:
Onkyo TX-NR3010 9.2 AVR
Emotiva XPA-3 amp
Oppo BDP-93 Blu-ray player
Epson 8500UB 1080p projector
Elite Screens Sable 120" CineWhite screen -
Insulated 12x24 room yesterday. Start rocking next week. Cant wait to compare traditional 7.1 vs. DSX w/width. I got the Denon4310ci, plenty of power, but I will have to re calibrate room for each test, too bad that a receiver at this level cant remember 2-3 preferences.
How much did it cost you to insulate the room? -
Materials only, my son is remodeling room. He tore out paneling, so we were looking at new construction. Started out," Heh dad you guys need a theatre room." Well I got the bug. The insulation is not really expensive, all the other parts of remodeling existing building would not have been an option for me if my son had not done it.How much did it cost you to insulate the room?
Sheetrock is up, electrician is waiting to finish, getting a quote for tape,mud/finish, paint.
I am still married!
I cant wait. I fell into the "well for just a little more" frame of mind.
All the gear is here. I am still married! I am one lucky dog.
