Computer help - Awareness Technologies Webwatcher Software
wayne3burk
Hey -- I hate to even post this on here..... but, my daughter is separated from her husband of 2 yrs. She moved out about a month ago, and last week he gave her the laptop computer to use (she has an iMac at their townhouse, the laptop is his).
She checked their joint checking / credit card account today and saw that he made a charge for something from awareness technologies - the makers of webwatcher software. He made the charge before he gave her the laptop.
Does anyone here know how to remove an invisible - keylogging - spying from anywhere software.
I'm thinking I'll have to contact Dell support and get a copy of windows 7 and reformat the hard drive.
Thanks in advance,
wayne
Thanks in advance,
wayne
Yamaha RX-V2700, EMI 711As (front), RCA K-16 (rear), Magnavox Console (Center & TV Stand), Sony SMP-N200 media streamer, Dual 1249 TT =--- Sharp Aquas 60" LCD tellie
Post edited by wayne3burk on
keyloggers are fun but it could be well hidden in any directory. I would run Malwarebytes which should catch it. If nothing comes up then yes the best way to rid of it is to format. You could also run CCleaner and rid of the installation that way, CCleaner would also remove registry entries installed the by the exe.Shoot the jumper.....................BALLIN.............!!!!!
A quick google turned up this: http://www.wikihow.com/Detect-and-Remove-Webwatcher
You could try those instructions... you're right that the only way to be sure it's gone is to reformat the HD and reinstall the OS. Most Dell's come with a CD that allows you to reinstall a clean image of the OS they came with and all the drivers. If it's the husband's laptop, she should give it back to him and get her own. I believe what the husband did is illegal, and she might want to give the laptop to her divorce attorney before you mess with it further. -
combofix http://www.bleepingcomputer.com/download/anti-virus/combofix
or if your a experienced user you could use hijackthis
http://download.cnet.com/Trend-Micro-HijackThis/3000-8022_4-10227353.html
dont use hijackthis unless you really know what your doing its very easy to render a pc useless with this app. I only use it when all else fails, combofix will usally clean any pc. Hijackthis is last resort before a reformat.
TV: Philips 42" LCD 1080p
Front Speakers: Polk Audio RT800i
Center Speaker: Polk Audio CS1
Surround Speakers: Polk Audio R50's powered of Denon AVR
Subwoofer: Polk Audio DSW pro500
AVR: Denon 3801
DVD Player: Denon DVM 745 upscale 1080p
Sat: Directtv HD 10
Front Speakers Amp: Rotel RB 890
Center Speaker amp: Rotel 970 BX -
I've seen many of the cleaners mentioned miss rootkits on Windows XP, so I'd run a couple of different ones. I've had good luck with combofix too, but you definitely need to make sure your anti-virus software is shut down before running that one.
I'll say again though, just because you could spend your time trying to deal with this doesn't mean it's a good idea. Or as we say at work... don't try to come up with an engineering solution to a people problem.
