Carver pro amps - Common Ground?
Bnewsom
Bnewsom Posts: 26
edited February 2011 in Vintage Speakers
Can someone tell me if the Carver PM-600 is common ground. I know it's
pro audio, but have a chance to pick one up cheap. My carver 1.5t went
out will be sending to be repaired. Can use this one untill repaired and still
have as a backup. I've searched here and could not find a mention of the pro
series. I found a thread of what Carvers are not, but still want to be sure.
Thanks for any help.
Post edited by Bnewsom on
  • thuffman03
    thuffman03 Posts: 1,325
    I think that it is a common ground but I would wait till someone who has had one to chime in.
    Sunfire TGP, Sunfire Cinema Grand, Sunfire 300~2 (2), Sunfire True Sub (2),Carver ALS Platinum, Carver AL III, TFM-55, C-19, C-9, TX-8, SDA-490t, SDA-390t
  • TNRabbit
    TNRabbit Posts: 2,168
    Here ya go; EVERYTHING.......except if it's common ground or not~
    PM-600
    8-ohm FTC rated power/ch 200W
    4-ohm FTC rated power/ch 300W
    Bridged mono power 700W
    4/8-ohm FTC rated THD 0.5%
    IM Distortion less than 0.1%
    Input Impedance (Line) 15k ohm
    Input Sensitivity 1.5Vrms
    Gain 28.5dB
    Rated full power bandwidth +0, -3dB at 5Hz & 80kHz
    Slew Rate 25V/u sec
    Power Consumption 950 Watts
    Fusing 8 amp slo-blo
    Damping 200 at 1kHz
    Dimensions (HxWxD inches) 3.5" x 19" x 11.56"
    Architect's and Engineer's Specifications
    The power amplifier being of two channels, shall deliver 200W into 8 ohms with both channels operating, or 300W into 4 ohms with both channels operating. The amplifier shall be capable of bridge-mode operation thereby providing 700W RMS output into 8 ohms and supplying a 70-volt distribution system without output matching transformers. The amplifier shall have a thermal shutdown system to protect the power devices from over-temperature operation. This thermal protection system shall be self-resetting. A protection LED indicator shall activate and the amplifier shall shut down to protect against short circuits and excessive high frequencies at the outputs, DC offset present at the outputs, or an internal power supply fault. The amplifier shall be capable of sequential turn-on/off and remote turn-on/off with a DC voltage between +5 and +15Vdc at the receive terminals. A delayed send voltage of 11Vdc shall be provided at the send terminals to turn subsequent amplifiers with this feature. The amplifier shall have slow start up and muted inputs of turn-on. Optional signal processing shall be available to be installed at the rear of the amplifier. The amplifier shall have a voltage gain of 28.5dB. Noise shall be at least 115dB below 40Vrms, A-Weighted, from 20Hz to 20kHz. Total harmonic distortion shall be less that 0.5% and inter modulation distortion shall be less than 0.1%. The front panel controls shall consist of independent level controls for left and right channels, a master power switch and a sequential operation switch. The dimensions shall allow for standard 19" EIA rack mounting. It shall be 3.5" high and 11.56" deep. The amplifier shall weigh 23 pounds. The power requirements shall be 120V, 60Hz, 960W. The frequency response shall be +0, -3dB at 3Hz and 80kHz. The power amplifier shall be CARVER PM-600.
    Features
    • 300 + 300 watts into 4 ohms.
    • High-efficiency linear tracking output design.
    • Highly-regulated magnetic field power supply.
    • L/R level controls with 11 precision detents.
    • Remote/manual sequential power on/off.
    • Dual-stage slow power-up.
    • Clipping eliminator circuitry with back panel switch.
    • Heavy duty 5-way speaker binding posts.
    • XLR, TRS and barrier strip inputs.
    • Switchable XLR pin configuration.
    • Dual-channel 7-segment LED display.
    - 1 bottom green "ON" LED per channel.
    - 5 red output level LED's per channel.
    - 1 yellow clipping/clipping eliminator indicator/protection activated LED per channel.
    • Protection circuits:
    - L/R-ch. Thermal.
    - Independent L/R-ch. Short Circuit.
    - Independent L/R-ch. Ultrasonic.
    - DC offset.
    • Rear cover card slot for use with Carver add-in options such as the PMX Crossover or PG2 Dual-Zone Paging Module.
    • 70-volt transformer option.
    • 70-volt direct drive capability.
    • Passive convection cooling system.
    TNRabbit
    NO Polk Audio Equipment :eek:
    Sunfire TG-IV
    Ashly 1001 Active Crossover
    Rane PEQ-15 Parametric Equalizers x 2
    Sunfire Cinema Grand Signature Seven
    Carver AL-III Speakers
    Klipsch RT-12d Subwoofer
  • ben62670
    ben62670 Posts: 15,969
    Take a multi meter and read resistance across the speaker grounds with nothing hooked up to it. No resistance you have common ground.
    Ben
  • Bnewsom
    Bnewsom Posts: 26
    Thanks for the replies, but I'm not planing on buy if not common ground. This will be for my sda's.
    Trying to email Rita's vintage repair, but do not expect a quick reply.
  • warren
    warren Posts: 756
    Ben you are the man!!!
    Some final words,
    "If you keep banging your head against the wall,
    you're going to have headaches."
    Warren
  • Joe08867
    Joe08867 Posts: 3,919
    My guess is it is common ground, most Pro amps are unless of course they are mono amps.
    I would do the Ben test just in case.
  • Bnewsom
    Bnewsom Posts: 26
    Again thank to everyone that took the time to reply. Rita's Vintage Audio confirmed that it is indeed a common ground.
  • DaveHo
    DaveHo Posts: 3,583
    Call Carver, they can tell you. How cheap is cheap? If the price is right, you should be able to re-sell, maybe make a little on it.
    -Dave
    I should type faster. Let us know how you like it.
