Do I need an airhole.....
T_Unit616
Do I need an air hole for my sub box? Pioneer 12" 400 Watt, box dimensons: 9 inches tall, 14 wide, and 15 long.
Post edited by T_Unit616 on
T_Unit616 wrote:Do I need an air hole for my sub box? Pioneer 12" 400 Watt, box dimensons: 9 inches tall, 14 wide, and 15 long.
If you are asking about a "port", a little research for your sub would be in order, to see if it's suited to a ported enclosure.
Pioneer likely has two possible enclosures recommended for your sub. One would be sealed (and small), the other would be ported (and probably larger). -
...if you are a porpoiseSharp Elite 70
Anthem D2V 3D
Parasound 5250
Parasound HCA 1000 A
Parasound HCA 1000
Oppo BDP 95
Von Schweikert LCR 4 Center
Totem Mask Surrounds X4
Sony PS3
Squeezebox Touch
You really need the exact model number of your Pioneer sub, and then you should look at Pioneer's website for box options.
Some woofers are designed to be used either ported, sealed, and some are OK for both- it really depends on which one you own.
As far as your post in the other thread,T_Unit616 wrote:Like nobody helps here man it is ****
...I wish you luck in your search.
You should try thisforum-
http://www.caraudioforum.com/vbb3/index.php
CarAudioForum.com - The WWW Car Audio Forum
They are far more knowledgeable about airholes. -
wingnut4772 wrote:...if you are a porpoise
Brilliant!!!
Do you need an airhole?
No. Sealed is better.polkaudio sound quality competitor since 2005
T_Unit616 wrote:Is there help for me being a moron?comment comment comment comment. bitchy.
Sharp Elite 70
Anthem D2V 3D
Parasound 5250
Parasound HCA 1000
Oppo BDP 95
Sony PS3
Squeezebox Touch
you forgot to tell everyone its in a cardboard box, just to make sure someone doesn't give you the wrong information;)AVR: H/K AVR240
Fronts: Monitor 50s
Center: CSI3
surrounds: R15s
Sub:Velodyne DPS10
Dvd/Cd: Samsung HD upconverter (for now)
TV: 50" Sammy Plasma
game hardware: 360 and gcn.
Gamertag: kovster27 -
Let me think....._________________________________________________
Never a dull moment here! Got Polk? It's better than COMEDY CENTRAL!
Good to know there are still people out there who make me look good :biggrin:- Computer Rig -
YAΘIN MS-20L, polkaudio RT5
- Main Rig -
Pioneer SC-37, Overnight Sensations, Samsung 52" LCD
- Currently In Progress -
Curt Campbell's Uluwatu LCR, LMS Ultra Gjallarhorn, JBL W15GTi stereo subs, 2.1 entertainment system for the gf -
Did it suffocate?Main Surround -
Den - Rotel RSP-1068 / Threshold CAS-2 / Boston VR-M60 / BDP-05FD -
I couldn't agree more.- Computer Rig -
- Main Rig -
LMAO! Forgot all about this guy. Cardboard box!!! Yeah, really a cardboard box for a sub enclosure and with a straight face! But it pounds.
http://www.polkaudio.com/forums/showpost.php?p=491981&postcount=6polkaudio sound quality competitor since 2005
Do I need an airhole.....DARE TO SOAR:
Your attitude, almost always determine your altitude in life -
