If you are asking about a "port", a little research for your sub would be in order, to see if it's suited to a ported enclosure.
Pioneer likely has two possible enclosures recommended for your sub. One would be sealed (and small), the other would be ported (and probably larger).
Anthem D2V 3D
Parasound 5250
Parasound HCA 1000 A
Parasound HCA 1000
Oppo BDP 95
Von Schweikert LCR 4 Center
Totem Mask Surrounds X4
Sony PS3
Squeezebox Touch
You really need the exact model number of your Pioneer sub, and then you should look at Pioneer's website for box options.
Some woofers are designed to be used either ported, sealed, and some are OK for both- it really depends on which one you own.
As far as your post in the other thread,
...I wish you luck in your search.
You should try thisforum-
http://www.caraudioforum.com/vbb3/index.php
CarAudioForum.com - The WWW Car Audio Forum
They are far more knowledgeable about airholes.
Brilliant!!!
Do you need an airhole?
No. Sealed is better.
Anthem D2V 3D
Parasound 5250
Parasound HCA 1000
Oppo BDP 95
Sony PS3
Squeezebox Touch
you forgot to tell everyone its in a cardboard box, just to make sure someone doesn't give you the wrong information;)
Fronts: Monitor 50s
Center: CSI3
surrounds: R15s
Sub:Velodyne DPS10
Dvd/Cd: Samsung HD upconverter (for now)
TV: 50" Sammy Plasma
game hardware: 360 and gcn.
Gamertag: kovster27
SOPA
cnh
YAΘIN MS-20L, polkaudio RT5
- Main Rig -
Pioneer SC-37, Overnight Sensations, Samsung 52" LCD
- Currently In Progress -
Curt Campbell's Uluwatu LCR, LMS Ultra Gjallarhorn, JBL W15GTi stereo subs, 2.1 entertainment system for the gf
- Main Rig -
http://www.polkaudio.com/forums/showpost.php?p=491981&postcount=6
http://www.polkaudio.com/forums/showthread.php?t=42855
