Best 5.1 amp
z3r0m4g3
I need to know what would be the best amp 5.1 only, I have no need for a 7.1 setup. I would connect my polk mon 70's as fronts, my cs10 (center), I use sony ssf-6000 for surrounds for now, and have a polk psw-110 for my sub. Im always listening to extremely loud music mostly heavy metal, and rock and want watts per channel around 125 per, and possibly a pre amp output, or two. Not sure what to look for if any of you can help me that would be greatly appreciated. Oh lets try to keep it around the 300 to 500 range if at all possible thanks, Jason
Post edited by z3r0m4g3 on
You want an amp or a receiver?
Go with a Pioneer 1020k or Onkyo 608
If you go used you can get more for your money....
If you go new, the good stuff is all 7.1, even if you don't use all 7 channels.Main Surround -
Den - Rotel RSP-1068 / Threshold CAS-2 / Boston VR-M60 / BDP-05FD -
If you get the pioneer (which i have, its great) it has no pre outs, but runs way cooler then the onkyo. But the onkyo has pre outs if you decide to get crazy with an external ampHome Theater Setup
- Receiver - Onkyo TX-RZ1100
- Mains - Polk RTi A9's
- External Amps - Outlaw 2200 Monoblocks for L/R/C
- Center - Polk CSiA6
- Side Surrounds - Polk FXiA6's
- Atmos - 4 Polk 80F/X RT's
- Sub - SVS PC-4000
- T.V. - LG OLED65C7P
