Onkyo TX-SR508 and Polk Monitor 70's - Enough power?
The_Gladiator
The_Gladiator Posts: 5
edited February 2011 in Speakers
Hi all,
I've been looking around forum gathering intelligence for some time.
I finally picked my setup. I'm VERY limited on budget now so I picked Onkyo TX-SR508 and 2x Polk Monitor 70. I will have just that for now (mostly stereo music).
My main question is: Does the receiver I picked have enough power for these speakers?
We rent an apartment, so I will definitely not play it loud or anything. I watch movies, listen to music and play XboX in a 14'x14' room.
I don't really need suggestions, rather just know if that is powerful enough so my bass freq do not suffer/I'm using the maximum bass these can put out.
Thank you for any kind of answer!
English is my second language, so be nice to me :biggrin:
Post edited by The_Gladiator on
  • spock 2054
    spock 2054 Posts: 163
    Welcome to CP.
    If you watch movies, have you thought about adding a sub and/or surround speakers? For music, with the 508, bass response from the 70's should be fine - but for movies, you would be missing the added punch of a sub and surrounds.
    polk monitor 70's
    center - polk monitor cs2
    surround - polk monitor 60's
    surround back - jbl e10
    sub - velodyne dps 12
    sub - polk psw110
    avr/pre-amp - onkyo tx-nr809
    amp - adcom gfa-5500
    amp - carver av405
    display - sharp lc70le847u
    tv - silicon dust hd homern
    blu-ray - oppo bdp-103
    hd dvd- toshiba hd xa2
    control - logitech harmony one
    turntable - technics sl1500 mkII
  • The_Gladiator
    Thank you :)
    Sorry for dumb question but what you're basically saying is that I "would be missing the added punch" because of missing sub and not because of not enough power from the receiver?
    I want to start with just 2.0 setup for now (being very limited $$$-wise) and I will have to make some sacrifices. But I hear you and I will probably have to supply the sub in the near future.
  • spock 2054
    Exactly. Without a sub, I can hear the bass from my 70's at moderate listening levels - with the sub, I can feel the bass and low frequency effects. When you do pick up a sub, there are ways to isolate it so as not to piss off your neighbors...the joy of apartment livin'.
    polk monitor 70's
    sub - polk psw110
    amp - carver av405
  • The_Gladiator
    How to do you isolate it? Or what do you mean by that?
    Yeah...can't wait to have a house in the future. We're already pissing off the neighbors downstairs with our jumping and scream while playing Kinect, LOL :)
  • Geoff4rfc
    Geoff4rfc Posts: 2,805
    Hi all,
    The 508 should do fine with the 70's, especially after break-in. Will you be getting max bass out put with that receiver? Since you'll only be driving 2 channels, I'd think you'd be getting pretty close.
    Source: BRP Panasonic UB9000, CDP Emotiva ERC3 - Display: LG OLED EVO 83 C3 - Pre/Pro: Marantz 8802A - Amplification: Emotiva XPA-DR3, XPA-2 x 2, XPA-6, Speakers, Mains/2ch-Focal Kanta No2's, C-LSiM706, S-702F/X, RS-RTiA9's, WS-RTiA9's, FH-RTiA3's, Subs - Epik Empire x 2
    Cables: AudioQuest McKenzie XLR's/CDP/Amp, Carbon 48/BRP, Forest 48/Display, 2 channel speaker cable: Furutech FS Alpha 36 12AWG PCOCC Single Crystal (Douglas Connection)
  • logo896
    logo896 Posts: 322
    Have you set bi amped them? Using your B channel for the lows and then A channel on the highs will help quite a bit. Make sure you remove the bridge plates though before you turn your receiver on.
    You can drive M-70s with an Onkyo 50x but don't expect much bass response. You'd be BETTER off getting a SUB and crossing our M-70s over at 80hz so as to RELIEVE that entry Onkyo of the burden of those towers and allow it to do it's best serving the mid-bass and higher frequencies on your fronts.
    On paper, M-70s are fairly efficient but in practice, you're powering 10 drivers between the two of them. I wouldn't go lower than an Onkyo 600 series with those in front and preferably a 708 or higher. But, as I said, for HT, a sub will serve you WELL. And you won't have to worry about the power.
    cnh
  • marinpaul
    marinpaul Posts: 5
    I have the 508 with two 70's and no subwoofer. For 2 channel music it sounds great to me. And while I will probably will get a subwoofer in the future, the 508 does just fine with a CS2 center and OWM5 surrounds. Enjoy.
  • spock 2054
    LMAO....Did a search of subwoofer isolation:
    http://www.google.com/search?aq=f&sourceid=chrome&ie=UTF-8&q=subwoofer+isolation
    Some of the Polkies suggest the Auralex SubDude...
    polk monitor 70's
    sub - polk psw110
    amp - carver av405
  • inthewoods
    inthewoods Posts: 54
    cnh wrote: »
    Agreed!
    My M70 + 608 sound good in 2.0 mode but the bass is nothing spectacular.
    In 2.1 mode the M70's get louder and sound much better since it's not having to worry about the stuff below 80hz.
    Panasonic 58" Viera S2 Plasma | Onkyo TX-SR608 | Monitor 70 Series II | CS2 | PSW505 | RC60i
  • The_Gladiator
    One more question - how can one tells that the receiver doesn't have enough power for the speakers?
    Is it that it cannot play that loud or is it that some frequencies will not be as strong as they should be?
    Thank you :)
  • dvran
    dvran Posts: 280
    Do the Onkyo 608 and get a center since your apartment will limit the bass you can put out.
    That way at least you have a front sound stage.
    ~Dan
    Projector: Epson 705HD on 106" DaLite
    TV: Samsung 50" Plasma PN50B550
    Receiver: Onkyo 607
    Fronts: Polk 1000i
    Center: Polk Csi40
    Rears: Polk Fxi30
    Sub: Velodyne Minivee 10
    PS3 and Xbox
  • The_Gladiator
    I just hooked the whole thing up over the weekend and I have to say that the TX-SR508 is more than adequate for those Polk Monitor II 70's!
    This is my first REAL and TRUE audio system (used to have only PC speakers before) and I'm by no means an audioholic or professional listener and I LIKE a lot of bass.
    This setup has so much bass that I had to actually tone it down on the receiver. It plays very loud and since we rent an apartment, I can play it only so much loud.
    And because I'm not a professional, anything more expensive than what I had sounds much much better. So I think I wouldn't be able to appreciate anything better at this point - I couldn't tell the difference, I guess. After my ears learn, get used to a semi-pro sound and I "musically grow" (and we move out :) ) then I will get the rest of the 7.1 system this baby can handle.
    So far, I've been very happy with this combo, which I use for music (rock), movies, regular TV and Xbox gaming.
    Thanks everyone for their opinions :)
  • dnoyeB
    dnoyeB Posts: 114
    I have an Onkyo HT-RC270. I played some jazz with my Monitor 70s. The volume was at max. It was very clear. It was not painful. This receiver does not have enough power to distort these speakers. There is much room left over. I imagine if I bi-amp them, I could get to distortion volume.
    My present opinion is that the receiver has enough power to play music loud and clear. But on a friday night when I'm sipping whiskey and listening to undeground rap, I'm going to have to figure something out...
    Music
    LR: Polk Monitor 70 (willing to sell if interested)
    C: Cerwin Vega E-75C
    Sub: HSU VTF-2 MK3
    AVR: Sony STR-DE835
    AMP:
    HT
    5.1: Paradigm CT110
    AVR: Integra DTR-4.6
    WTB: RTiA9 or RTi12
    tonyb Posts: 33,068
    dnoyeB wrote: »
    Volume at max ?? Not enough power to distort the speakers ??
    Bi-amping to get to distortion levels ??
    Best you stop on the cheap whiskey and start buying the good stuff.
  • dnoyeB
    dnoyeB Posts: 114
    Its not that I like distortion. I'm trying to express that the amplifier is not enough for these speakers. It works, but i'm used to having to back off the volume.
    Music
    Sub: HSU VTF-2 MK3
    AVR: Sony STR-DE835
    AMP:
    HT
    5.1: Paradigm CT110
    WTB: RTiA9 or RTi12
  • mystik610
    mystik610 Posts: 699
    Provided you aren't severly underpowering a speaker (ie driving with an amp that can't dip low enough in impedence), adding external amplification has a lot more to do with dynamic range and sound quality than it does volume. Even a very efficient speaker like the monitor 50 will benefit greatly from being fed quality amplification.
    That being said, the Monitor 70's are very efficient for a full-range speaker (90db efficiency), and they're 8ohm speakers. You should not have any trouble running them off an AVR, unless you're pushing them above reference levels for extended periods of time.
    My System Showcase!
    Media Room
    Paradigm Studio 60 - Paradigm CC-690 - Paradigm ADP-390 - Epik Empire - Anthem MRX300 - Emotiva XPA-5
    Living-room
    Paradigm MilleniaOne - Rythmik F12GSE - Onkyo TX-SR805 - Adcom 5400
    Headphones
    Sennheiser Momentum Over-Ear - Shure SE215 - Fiio E18 Kunlun
