Infinity Kappa 62.9i NIB Pair
Unknown
edited February 2011 in Garage Sale
Brand new never used Infinity Kappa 62.9i in tattered box.
Bought these new and never used or hooked up, they have been in a storage room, hence the tattered box.
6.5" coax.'
$50/shipped (Lower 48 states only).
Paypal or US Postal money order only, no exceptions.
If using Paypal please use "gift" so I am not charged the fee.
  • Systems
    Systems Posts: 14,872
    edited December 2010
    Please do not make me mount them in the 6.5"ProBox Rhino lined sealed boxes!
    Available to the buyer for $20.00 extra.
    Not a screw hole, never had anything mounted in these boxes!
    $70.00 shipped for the boxes, and Kappa's.:biggrin:
    Testing
    Testing
    Testing
  • Systems
    Need something to drive em?
    Farenheit CLX-260-2 Never used or hooked up.
    Still some scuffs on Plexiglass.
    I assure you this has NEVER been used (you can look @ the screws).
    I bought it new, and has only been out of the box twice.
    Once before, and for these pics.
    NEVER HAD ANY AMPS THROUGH IT!
    Specs are listed in last pic.
    Add $35/shipped.
    $110 for all of the above/SHIPPED!
    $105/Shipped for all 3 (speakers, boxes, amp).
    Testing
    Testing
    Testing
  • codes1
    codes1 Posts: 17
    are the boxes you have large enough for 6.5 in subs?
  • Systems
    codes1 wrote: »
    I would not recommend them for subs.
    I don't think there would be enough internal volume for that.
    They are made more for Coaxial fullranges.
    I am sure you could make some boxes for your subs with alittle research and rhinoline them yourself with some truck bedliner spray.
    Any parts store should have it.
    You may want to talk with ProBox, because I know they can make custom boxes or may already offer one, not sure.
    Testing
    Testing
    Testing
  • Face
    Face Posts: 14,340
    FYI, none of your pictures are working.
  • Systems
    Face wrote: »
    I gave up, no interest, the original add is a couple of months old.
    I had 1 offer on the above, and it was pretty much for me to pay them to take them.:mad:
    Testing
    Testing
    Testing
  • Systems
    Heres what they look like (I do not think they will meet your needs for a sub).
    ProBox makes the best boxes IMHO, and are priced very fair considering the quality.
    There is a local dealer here, and I needed an 8" sealed sub box, we just called them up, and they made one (even though they did not offer that at the time), had it to me in 1 week.
    So you might look into it, tell them your volume and size of woofer, and I am sure they can make you one.
    They are really easy to deal with.
    These are alittle dusty.:eek:
    Good luck!
    Testing
    Testing
    Testing
  • codes1
    codes1 Posts: 17
    Are these both slanted like the one laying down?
  • Systems
    Yes they are......
    Testing
    Testing
    Testing
