Subwoofer Cable???
loudandproud
Can anyone shead some light on the difference between a subwoofer cable and a digital rca cable?? Should i be using a subwoofer cable for my sub....i have the RM705 system.
Post edited by loudandproud on
They are both coaxial cable with rca connectors on them. I make my own out of quad shielded rg6 cable. No difference between the two.
Previously posted:
http://www.polkaudio.com/forums/showthread.php?t=33908
http://www.avforums.com/forums/interconnects-speaker-cables-switches/781107-what-difference-between-digital-coaxial-rca-subwoofer-cables.htmlpolk monitor 70's
center - polk monitor cs2
surround - polk monitor 60's
surround back - jbl e10
sub - velodyne dps 12
sub - polk psw110
avr/pre-amp - onkyo tx-nr809
amp - adcom gfa-5500
amp - carver av405
display - sharp lc70le847u
tv - silicon dust hd homern
blu-ray - oppo bdp-103
hd dvd- toshiba hd xa2
control - logitech harmony one
turntable - technics sl1500 mkII -
Thanks for the help!!
I made my own Sub cable using Neotech ND-021090 digital interconnect cable, and Vampire Wire C9X/CB connectors. Turned out to be a very nice cable.Sunfire Theater Grand IV
SRS 2.1TL
SDA 2BTL's
CSiA6
FXiA4
FXiA6
SDA 2A's
Monitor 10A's
http://www.douglasconnection.com -
spock 2054 wrote: »I make my own out of quad shielded rg6 cable. No difference between the two.
What's your connector of choice?________________
2 Channel-Denon AVR-4520/SDA 2.3TL's
5.1-Denon AVR-4500h/RT3000P's/CS1000P/RT2000P's/
