SDA-1C's
edited February 2011 in Vintage Speakers
I have a pair of SDA-1Cs in their original packaging. After reading a few posts here, it sounds like their are a couple different 1C models.
Can any one help me with what the differences are and how to ID the different models?
I purchased these new in 1991 at a Base Exchange in Germany for about $700.
They still sound and look perfect.
Mark Tanner
Oak Harbor, WA
Post edited by mbtanner on
Welcome!
    Hey Mark,
    Welcome... always good to have more members from the Puget Sound area, especially ones who own some of the more sought after vintage speakers. :wink:
    I think the main significant difference is that some of the earlier 1C's used an interconnect that had two flat blades on the plug and socket. Later models had an interconnect with one round pin and one flat blade. If you know what style of interconnect cable you have, that would help clear it up, as would serial numbers. With the serial numbers it matters whether the ser no. is for the left or right speaker, so if you check, that would be good to note also.
    This thread has a bunch of information on the various SDA speaker models: http://www.polkaudio.com/forums/showthread.php?t=55888
    In particular, the PDF's titled Transitional SDA's and SDA Series Driver And Crossover List are where some of this info comes from. The 1C schematic is there also, and based on the schematic date vs. your '91 purchase date my guess would be you don't have the blade/blade versions.
    There is also a "Studio" version of the 1C, but the differences there are essentially cosmetic.
    Lots of guys on the forum know way more about your speakers than I do... I just thought I attempt an answer in case you wanted to read up or check the ser nos. Again, welcome!
    -Scott
    It is the flat pin and round blade.
    Thanks Scott.
    Or round pin flat blade.
    There were two SDA 1C models.
    The standard:
    http://www.polksda.com/sda1c.shtml
    Or the studio:
    http://www.polksda.com/sda1c-studio.shtml
    Other than the differences in the cabinets they were essentially the same.
    And a review from 1987:
    http://www.polksda.com/sda1creview.shtml
    post a couple of pics front/back grills off, someone here will tell you all you want to know about 1C's--welcome aboard
    They look like the photo of the studios.
    We recently moved and I haven't un-boxed them yet (to take photos). I was thinking about putting them on Craigslist for free two days ago because I thought I wanted something smaller.
    After hanging out for a day here, you've convinced me to keep them. They have always been the centerpiece of my system, but considering they are 20 years old, I assumed that better technology existed. Now I'm not so sure.
    Thanks.
    Happy SDA owner.
    Tanner
    In some ways it does. There are upgrades to your speakers that will vastly improve the sound.
    +1 on that,, upgrade crossovers,Larry's rings,,replacement tweeters,, and you are good to go for many years of listening pleasure.
    mbtanner wrote: »
    I was thinking about putting them on Craigslist for free!!
    Or...if they still sound good (and they may)...enjoy them just the way they are.
    Welcome Tannar,I just completed a extensive mod on a pair of 1C's...everything is burning in now,they are slowly coming around and really starting to open up...well worth the time and effort...this is the second pair of modded 1C's I've had,sold the first pair,won't make that mistake again.
    Mike, how much did your Mod's cost you in parts? How long did it take you to complete?
    If you are speaking of the cap/resistor upgrade,it depends on the cap cost,,me,,I prefer Sonicaps all around with mills resistors,,so figure 200 dollars +/-,,if you go that route they (Sonicap) usually runs a sale from time to time @ 20% off which is the best time to buy,,Larry's ringset is anothe 100 or so,, tweeters are 48 each x 4,,however,you don't have to perform the mods to enjoy these speakers,,,just upgrade them bit by bit.Anyhow--congrats on a fine set of speakers.Have fun and enjoy.
    george has covered the caps,resistors and tweeters...I also used a Sonic Barrier material in the cabinets (about 160.00) if I remember right...Dynamat Supreme on all the driver baskets (25.00).New binding posts(cost varies) New Floor Spikes (also cost varies by quality) New Grill Cloth (25.00) I didn't redo the caps as they are in good shape.
    There are many threads here on SDA upgrades,here a good one http://www.polkaudio.com/forums/showthread.php?t=97719&highlight=upgrades
    I don't think "Larrys Rings" are available any longer,unless he decides to make some more.
    Hope this helps,Mike
Welcome!
Welcome!
