Formal living room speakers
thejck
thejck Posts: 849
edited February 2011 in Speakers
I am helping a friend choose speakers for his formal living room. This will be a 5.1 or 7.1 system.
He wants to them to blend into the room and not be very visible. In other words he wants his living room to stay as a formal living. He has a separate room as a home theater.
I do not have much experience in this as I have big tower speakers and never messed with in-wall stuff.
I was looking at some of Polk invisible line of wall speakers. Anyone have any experience with those? Any other recommendations or ideas at what to look at other than in-wall stuff.
Post edited by thejck on
  • VSchneider
    VSchneider Posts: 443
    edited January 2011
    Budget? Polk makes some very good in-walls, too, but prices vary a lot.
  • JimAckley
    JimAckley Posts: 1,138
    edited January 2011
    anonymouse wrote: »
    Any pictures of the layout? Is there a TV in the mix, or is this a 2 channel system?
    OP stated either 5.1 or 7.1.
    If there's an open attic above the room, you could go with an in-ceiling system and make it a rather simple and straightforward install. If not, this is going to become a good bit more difficult IMO. Then again, I'm not a professional installer, so I could be wrong :)
    - Computer Rig -
    YAΘIN MS-20L, polkaudio RT5
    - Main Rig -
    Pioneer SC-37, Overnight Sensations, Samsung 52" LCD
    - Currently In Progress -
    Curt Campbell's Uluwatu LCR, LMS Ultra Gjallarhorn, JBL W15GTi stereo subs, 2.1 entertainment system for the gf
  • thejck
    thejck Posts: 849
    edited January 2011
    probably just end up being 5.1.
    no budget is set yet. i am looking at ideas for him. one of the ideas is small towers in the front and in the rear either bookshelf or in-wall.
    ceiling is out of the question because ceiling is 2 floors tall. In-wall might work because there is a dropped ceiling below.
    There will be a TV and he already has an onkyo 808 receiver to go with it. So speakers will be powered by receiver.
    Not looking to get the best sound out of this because he has a separate theater room. He wants something that is functional and doesnt sound like crap or weak like small satellite speakers would.
    i was looking at the rtia line bookshelf because the curved back end gives a nice touch to it.
    the vanishing series of polk, how do you do the grill painting to get it to match ure walls?
  • VSchneider
    edited January 2011
    thejck wrote: »
    The new Vanishing series is what I was going to recommend initially. They also should be timbre-matched to LSi and RTi depending on the model for mix and match. If specs are right, they all are 8-Ohm nominal and relatively efficient, unlike LSi's for example. Could that be true?
    I thought a couple of folks here have already heard them, so they might chime in, too. Mark? Ken?
    Usually you must spray paint the grills, no roller.
  • skipf
    skipf Posts: 694
    edited January 2011
    Might be a silly question, but why do you want 5.1 or 7.1 in a living room? A great two channel system will sound better if you aren't doing home theatre.
  • Geoff4rfc
    Geoff4rfc Posts: 2,833
    edited January 2011
    skipf wrote: »
    There is some great information here, the only thing I could add would to be; buy camouflage paint or the new H.D. transparent paint from Hi-Def world. :biggrin:
    Set up:
    Marantz AV8802A - Sources: BRP Panasonic 9000/CDP Emotiva ERC 3 - Display: LG OLED EVO 83 C3 - Amplification: Emotiva XPA-DR3, XPA-6, XPA-2 x 2 - Speakers: Focal/PolkAudio, Mains/2ch - Kanta No2, C - LSiM706, SS - LSiM702, WS - RTiA9, RS - RTiA9, FH - RTiA3 - Subs: Epik Empires x 2
    Cables: AQ McKenzie XLR's from CDP to AVP to amp for 2ch, Emotiva XLR's for the rest - Douglasconnection: Furutech Alpha 36 12g speaker wire for 2ch, Furez 10g speaker wire for the rest - AQ Forest48 HDMI for the display, AQ Carbon48 HDMI from BRP to AVP - VR3 filtered power cables for CDP, BRP and AVP, Emotiva power cables for the amps - AudioQuest 505 power conditioner.
  • thejck
    thejck Posts: 849
    one of the possibilities would be to stick with a 3 channel setup.
    On the VM series..what do they sound like. From what I understood they are plastic cabs?
