IC Cable question
NotaSuv
NotaSuv Posts: 3,871
edited February 2011 in 2 Channel Audio
I just added a Azur 840c to my 2 channel which consists of a W4S ST500 int amp, the 840 and a pair of Mirage M-1s...right now I am using the rcas would there be that much of a difference if I used the balanced outputs....right now it sounds wonderful, as the 840 really raised the bar and I listen to 100% cds...old school and just like the discs.... have no problem with putting out for a good set of cables as I do believe..........
Thanks for any input....
Post edited by NotaSuv on
  • ben62670
    ben62670 Posts: 15,969
    edited January 2011
    It depends on the design of the gear if indeed it is fully balanced on both ends. Also with that short of a run RCA is fine, and you have many more cable options running RCA's. Remember if you try XLR's there is a 3-6db boost that some mistake as cleaner sound.
    Ben
  • Polkitup2
    Polkitup2 Posts: 1,640
    edited January 2011
    Here's what EJ says about the STI-500 from AVS forum:
    "Due to the size constraints, the volume control circuitry is single-ended. The balanced input uses a balanced line receiver to convert it to an unbalanced signal. After the volume control is the line-stage which also doubles as an unbalanced to balanced converter. This considerably reduces the common mode noise found in unbalanced designs. "
  • NotaSuv
    edited January 2011
    Found the W4S thread there ^^^^ tons of info and answers the question...thanks
  • falconcry72
    falconcry72 Posts: 3,580
    edited January 2011
    NotaSuv wrote: »
    There's tons on info on the subject here too, just search.:smile:
    The short answer is that, because it depends on your gear, you just have to try it and see for yourself.
    I've run my rig fully bablanced from the DAC to the preamp to the amp, and, for that gear and my ear, I prefered single-ended unbalanced RCA's. Don't know why, don't really care; It sounds better to me.
  • Flash21
    Flash21 Posts: 316
    edited January 2011
    When I had the 840C the Zu Varial XLR interconnects really worked well for me...always hard to predict if they would work well for you too, but if nothing else both of our amps are digital...
    Steve Carlson
    Von Schweikert VR-33 speakers
    Bel Canto eVo2i integrated amp
    Bel Canto PL-2 universal disc player
    Analysis Plus Oval Nine speaker cables and Copper Oval-In Micro interconnects
    VH Audio Flavor 4 power cables
    Polk Monitor 10B speakers, retired but not forgotten
  • leftwinger57
    leftwinger57 Posts: 2,917
    Hi Guys.
    I've been following most threads about you dudes swapping out one wire for another and then chageing back then trying another pair. If I did any more moves I would not have a floor left for my rig to be on. Do you really gut out wires and change them, it just seems that once your gear is set it's not moving unless your moving or selling so of it off. I have nice hardwood floors and everytime i move the rack there's another scrath in the floor. Any preventive measusures taken because I know wives really don't like this kind of thing.....LW
  • quadzilla
    quadzilla Posts: 1,543
    Home Depot sells floor protectors. Tried those?
    Turntable: Empire 208
    Arm: Rega 300
    Cart: Shelter 501 III
    Phono Pre: dsachs consulting
    Digital: Marantz SACD 30n
    Pre: Conrad Johnson ET3 SE
  • NotaSuv
    Gear and rack stay put, even with all the cable/IC swapping,just reach around and swap em out....
