LED's
F1nut
F1nut Posts: 51,749
edited February 2011 in Electronics
I'm looking for 5mm bi-color (Red/Blue) thru hole LED's with two leads (bi-polar), non-flashing.
Post edited by F1nut on
  • FTGV
    FTGV Posts: 3,650
    edited January 2011
    I have some green/reds.
    F1nut Posts: 51,749
    edited January 2011
    Thanks, I appreciate the offer. The situation is that I have a red/green in a piece of gear already and want to change it to a red/blue. I've been looking everywhere and found plenty of red/greens, but no red/blue other than those that flash.
  • FTGV
    FTGV Posts: 3,650
    edited January 2011
    You might find the blue to not be a drop in replacement as it may have a different operating voltage.A resistor change may be necessary.
    F1nut Posts: 51,749
    edited January 2011
    Yes, I am aware that a new LED may require changing the resistors. Now, if I could only find a damn red/blue LED.
  • skrol
    skrol Posts: 3,448
    edited January 2011
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • Glowrdr
    Glowrdr Posts: 1,103
    edited January 2011
    Not that it helps you any, but I found it quite interesting that when I googled red/blue LED's - everything I got in return was for hydroponic uses.
    I'll ask around, I know quite a few of the car guys are in the know with LED vendors for modding. Not sure there is much use for dual color lights in a car though, they may only have straight colors.
    65" Sony X900 (XBR-65X900E)
    Pioneer Elite SC-37
    Polk Monitor 70's (2)
    Polk Monitor 40's (4)
    Polk Monitor CS2
    Polk DSW Pro 660wi
    Oppo BDP-93
    Squeezebox Duet
    Belkin PureAV PF60
    Dish Network "The Hoppa"
    F1nut Posts: 51,749
    edited January 2011
    Stan, I don't know how you found that, but thanks!
    Other than the brightness (much higher than I want, but at this point I'm not going to be picky) they do not have any specs listed, so I sent them an email.
    Glowrdr, that would be great.
    F1nut Posts: 51,749
    edited January 2011
    Ok, they responded quickly and they do fit my needs. However, as I proceeded to checkout I was informed they have a $20.00 minimum order. I was going to order 10 for a total of $4.00 plus shipping. As they had nothing else that I want and I just happened to find some on eBay, I did not place an order with them at this time. I'll wait and see how the ones from eBay work out as they seem to be the same ones.
    Thanks to everyone for your help.
  • polkfarmboy
    polkfarmboy Posts: 5,703
    edited January 2011
    I had my suspicions you were a secret emotiva amp owner
  • TECHNOKID
    TECHNOKID Posts: 4,298
    edited January 2011
    deleted double post...
    DARE TO SOAR:
    “Your attitude, almost always determine your altitude in life” ;)
  • TECHNOKID
    edited January 2011
    REPORTED! F1 is an emo lover! :eek: You've just killed is reputation on this board! :eek:
    DARE TO SOAR:
  • dcmeigs
    dcmeigs Posts: 708
    edited January 2011
    Can you get by with a 5mm? Mouser has these these with no minimum order. They have a flange behind the lead that might help with mounting.
    The world is full of answers, some are right and some are wrong. - Neil Young
    F1nut Posts: 51,749
    I finished installing a red/blue LED in my pre amp and a blue one in the amp tonight. Neither job was exactly what one might call easy, but the results were worth it. Oh, look at the pretty BLUE lights. :biggrin:
