LED's
F1nut
I'm looking for 5mm bi-color (Red/Blue) thru hole LED's with two leads (bi-polar), non-flashing.
Post edited by F1nut on
I have some green/reds.
Thanks, I appreciate the offer. The situation is that I have a red/green in a piece of gear already and want to change it to a red/blue. I've been looking everywhere and found plenty of red/greens, but no red/blue other than those that flash.Political Correctness'.........defined
President of Club Polk -
You might find the blue to not be a drop in replacement as it may have a different operating voltage.A resistor change may be necessary.
Yes, I am aware that a new LED may require changing the resistors. Now, if I could only find a damn red/blue LED.Political Correctness'.........defined
How about this:
http://www.ledsales.com.au/catalog/index.php?main_page=product_info&cPath=148_187&products_id=755Stan
Main 2ch:
HT:
Other stuff:
Not that it helps you any, but I found it quite interesting that when I googled red/blue LED's - everything I got in return was for hydroponic uses.
I'll ask around, I know quite a few of the car guys are in the know with LED vendors for modding. Not sure there is much use for dual color lights in a car though, they may only have straight colors.65" Sony X900 (XBR-65X900E)
Pioneer Elite SC-37
Polk Monitor 70's (2)
Polk Monitor 40's (4)
Polk Monitor CS2
Polk DSW Pro 660wi
Oppo BDP-93
Squeezebox Duet
Belkin PureAV PF60
Dish Network "The Hoppa" -
Stan, I don't know how you found that, but thanks!
Other than the brightness (much higher than I want, but at this point I'm not going to be picky) they do not have any specs listed, so I sent them an email.
Glowrdr, that would be great.Political Correctness'.........defined
Ok, they responded quickly and they do fit my needs. However, as I proceeded to checkout I was informed they have a $20.00 minimum order. I was going to order 10 for a total of $4.00 plus shipping. As they had nothing else that I want and I just happened to find some on eBay, I did not place an order with them at this time. I'll wait and see how the ones from eBay work out as they seem to be the same ones.
Thanks to everyone for your help.Political Correctness'.........defined
I had my suspicions you were a secret emotiva amp owner -
deleted double post...DARE TO SOAR:
REPORTED! F1 is an emo lover! :eek: You've just killed is reputation on this board! :eek:polkfarmboy wrote: »I had my suspicions you were a secret emotiva amp ownerDARE TO SOAR:
Can you get by with a 5mm? Mouser has these these with no minimum order. They have a flange behind the lead that might help with mounting.The world is full of answers, some are right and some are wrong. - Neil Young
I finished installing a red/blue LED in my pre amp and a blue one in the amp tonight. Neither job was exactly what one might call easy, but the results were worth it. Oh, look at the pretty BLUE lights. :biggrin:Political Correctness'.........defined
