CSI3 orientation question?
Arcanum
Arcanum Posts: 7
Hi:
I have a CSI3 center and due to space requirements I have to have it in front of the tv on the floor. I want to get a 12" stand to bring it up off the floor, however. When I do, should I keep it inverted so that the speaker is still angled up or should I flip it so that it is flat on the stand? The viewing position is about 12' from the tv - straight in front.
Post edited by Arcanum on
  • warviper
    warviper Posts: 585
    edited February 2004
    I used a laser pointer to aim all of my speakers. You should aim it at your ear level in the primary listining position.
    Wish I was a polkologist then I could call my self Dr.warviper.
  • fireshoes
    fireshoes Posts: 3,167
    I'd vote for upside down.
  • RVJII
    RVJII Posts: 167
    Dito fireshoes...with it still pretty low you most likely want it aimed up.
    A lack of planning on your part does not constitute an emergency on my part...
  • ken brydson
    ken brydson Posts: 9,002
    I never thought of that. Good idea. Tweeters, right?
  • jd45177
    jd45177 Posts: 35
    I did the same thing, made setting up the speakers MUCH easier. Using a scale, I could set up my speakers relative to the listening position to within an eighth of an inch.
    Mains: Polkaudio RTi70's
    Center: Polkaudio CSi40
    Surrounds: Polkaudio RTi38's
    Rear Center: Polkaudio CSi30
    Sub: Polkaudio PSW-404
    Receiver: Pioneer Elite VSX-53TX
    DVD Player: Pioneer DV-414
    CD Player: Pioneer Elite PD-M59
    TV: Toshiba TZ-43V61
    Monster Power MP HTS 2000 MKII Power Center
  • warviper
    warviper Posts: 585
    Yea line it up with the tweeter.
