Adcom GFA-555 (original?)
nguyendot
nguyendot Posts: 3,594
edited February 2011 in Electronics
Just traded my CC-300 + klipsch sound dock for this amp in minty condition.
Thoughts on this model? It's not the II, and I have no idea what the difference is.
Speaking of which, I need to take that CC-300 off the for sale list
Main Surround -
Post edited by nguyendot on
  • raffi
    raffi Posts: 114
    edited January 2011
    My limited knowledge of the 555 is that it's a pretty good sounding (I can attest that it indeed is) amp for the $, and is rock solid dependability-wise (so far, so good). Judging from what they bring on Agon, ebay, and the FM here they seem to hold their value pretty well, and IIRC they're a tad more highly regarded than the II. I've only had mine for a few months but I'm quite pleased with it.
    2 channel rig: MMF 2.2 turntable, Adcom GFP-715, Adcom GFA-555, Adcom ACE-515, Carver M-1.0t, Denon 5900 CD/SACD, SDA-SRS 2.3s (Zardoss modded), AQ Diamondback & King Cobra IC's and AQ Type 4 speaker cables
    HT rig: Panny 50" G20 plasma, Directv DVR, Insignia BRD/DVD/SACD/DVD-A, Denon AVR-890, Fronts: Polk Monitor 70's, Rears: Deftech Mythos Gems, Center: Polk CS1, Sub: Polk PSW-505
  • Polkie2009
    Polkie2009 Posts: 3,834
    edited January 2011
    +1, I have to agree raffi, seems like more folks who have had both models prefer the original design. Not that the II's are slackers, sometimes, old things are better.
  • nguyendot
    edited January 2011
    Sounds good. I made a good deal then. He wanted my CC-300 (removed from flea market now) and another piece of equipment. Made out pretty well.
    Main Surround -
  • ben62670
    ben62670 Posts: 15,969
    edited January 2011
    The 555 is a solid amp. It is 2ohm stable stereo, and 4 ohm bridged:eek:
    Ben
    edited January 2011
    Ben knows his Adcoms better than I. I will add that I am also the owner of an original GFA-555...the gift that keeps on giving. Get yourself a good pre-amp and you'll be surprised just how clean this piece can sound.
    I've been rocking to mine for a couple of years now and am really only thinking of upgrading my pre to the GPA-750.
    And enjoy!
    cnh
  • nguyendot
    edited January 2011
    I've got a Yamaha pre, NAD 114, and Rotel RC-972 to play with the amp, hehe.
    Main Surround -
  • erniejade
    erniejade Posts: 6,321
    edited January 2011
    I have one. It is a solid amp!! for the $ cant beat it.
  • nguyendot
    edited January 2011
    Hooked it up to my Rotel RC-972 pre, DV-59AVi source, and RTi70 speakers for a test and even the guy selling/trading it to me was impressed.
    Main Surround -
    pitdogg2 Posts: 26,967
    edited January 2011
    ben62670 wrote: »
    and a Nelson Pass design which i don't think the 555 II is
  • nguyendot
    edited January 2011
    That's what I heard. What's the advantage to it?
    Main Surround -
    heiney9 Posts: 25,421
    edited January 2011
    nguyendot wrote: »
    It's in the archive, I've posted it atleast 1/2 dozen times in the past 2 years. Do a search and you will find all the info and more about Adcom 555's.
    I am not posting it again, I thinks 6 times is enough.
    edited January 2011
    Not really. The 555II was just made more complicated by Adcom engineers.
    http://www.linearaudio.nl/interviews/np.pdf
    See pp 12 and 13. The original 555 is less complicated and I feel it sounds better overall although the differences are slight.
  • nguyendot
    edited January 2011
    heiney9 wrote: »
    Gotta keep you on your toes somehow. I actually read through it all last night, along with all the quotes. Good info.
    Do the 3 vs 2 output transistors make it any less stable?
    Main Surround -
    edited January 2011
    nguyendot wrote: »
    Ok, good glad it helped.
    Not sure what you are referring to with 3 vs 2 output transistors. Did you also read the Stereophile reviews over the years? There is an on-line article about the 555II and they go into detail about the differences. They felt the II sounded better when compared directly to the original.
  • nguyendot
    edited January 2011
    Let me go read over it again, I swear they said the II model went to triple outputs.
    Main Surround -
    edited January 2011
    nguyendot wrote: »
    You are thinking of the "Triple Darlington outputs" that's a type of circuit not used in the original 555. They both use Bi-Polar output devices, the "Darlington" is a configuration. The Darlington outputs were used to allow the amp to drive 1 and 2 ohm loads, IIRC.
  • nguyendot
    edited January 2011
    Ah. Thanks for the clarification. I had no idea what it meant. Yeah I'm not powering any magnepans so no problem.... :)
    Main Surround -
    edited January 2011
    The 555II used dc servo's to adjust for slight variations of DC offset and that maybe also be the reason the "Darlington" output stage was used. The original 555 had a fixed output that didn't compensate for DC offset.
    edited January 2011
    nguyendot wrote: »
    Doesn't matter the 555 will power Maggies just fine. The torture test were the Apogee Scintilla speakers, the 555 had a few problems driving those (they reach down to 1/2 to 1 ohm) so the 555II with the Darlington output stage had much less issue driving those insane speakers.
    http://www.apogeespeakers.com/reviews/scintilla_stereophile.htm
  • nguyendot
    edited January 2011
    heiney9 wrote: »
    Interesting read, however I doubt I'll come across a pair any time soon.
    Main Surround -
  • Dawgfish
    Dawgfish Posts: 2,554
    edited January 2011
    I used to own one. It's definitely a solidly built workhorse and is a decent amp for the price. Replace the caps on it if it hasn't already been done and it should give you many more years of dependable service. I found the sound a little on the bright side for my tastes with the set-up I had then. YMMV.
  • ben62670
    edited January 2011
    The caps didn't fail on those. Only some of the 585's and the 565's. Fresh caps never would hurt though:smile:
    Ben
  • nguyendot
    edited January 2011
    Methinks this amp will be paired with RT-55s tonight for the hell of it.
    Should be good with 200w/channel to Polks best non-LSi bookshelf....and bass to boot.
    Main Surround -
  • nguyendot
    edited January 2011
    So I read that this amp has no output relays... is that why the amp still has sound after it is turned off until the capacitors are drained?
    Main Surround -
    edited January 2011
    nguyendot wrote: »
    Yep, well designed amps don't need current limiters or any type of soft start, muting, or output relays. I'll add that this is true for SS amps, tube amps may need a soft start or muting.
  • FTGV
    FTGV Posts: 3,650
    edited January 2011
    heiney9 wrote: »
    Actually many a "good" SS amp use mute relays and soft start circuits.Because of high in-rush currents involved with charging large amounts filter capacitance (and some toroidal type transformers) soft start are all most a necessity.Also if a mute relay is used to remove bias current at turn off it will be sonically benign.
    edited January 2011
    FTGV wrote: »
    Actually many a "good" SS amp use mute relays and soft start circuits.Because of high in-rush currents involved with charging large amounts filter capacitance and some toroidal type transformers soft start are all most a necessity.Also if a mute relay is used to remove bias current at turn off it will be sonically benign.
    Ok, I guess I'll be more specific, inexpensive and poorly designed mute relays, soft starts and the like are more detrimental than good. I've read many higher end designers state they would prefer not to use such devices unless absolutely necessary and yes, they can be integrated to be transparent but you don't find that on your everyday mass market piece.
  • nguyendot
    edited January 2011
    Sounds good. noticed it when I turned it on and off earlier. Had to wait longer to unhook it.
    Main Surround -
  • FTGV
    FTGV Posts: 3,650
    edited January 2011
    nguyendot wrote: »
    Yes the output stage is a triple darlington config,while having superior drive capability into lower impedances it is not considered to be the best approach for pure sound quality.
  • nguyendot
    edited January 2011
    H9 already answered that.
    Main Surround -
