New RTI-A7s Sound Bright
markiki
markiki Posts: 3
edited January 2011 in Speakers
Hello. I am new to the forum. I just recently replaced a pair of Monitor 10Bs with a pair of RTI-A7s.
My setup: Squeezebox Touch -> Rotel 60w/channel integrated amp -> RTI-A7s.
In listening to the new setup, on many recordings, it sounds like the high frequencies are somewhat over emphasized.
Has anyone encountered this before? Should I expect this to change over the breaking in period?
Thanks in advance for any input.
Thanks,
Mark
Post edited by markiki on
  • gfong
    gfong Posts: 1,079
    edited January 2011
    I had been using them for a year and they will mellow out a bit more over time. I feel that the speakers are fantastic for movies and home theater. Mulit channel SACD music was fantastic and 2 channel stereo was adequate. ( I found them a little bright as well)
    I have not heard Monitors, so I can not compare the 2.
  • danz1906
    danz1906 Posts: 5,144
    edited January 2011
    Welcome to the Club!
    The RTiA series are a little on the bright side.
    Linn AV5140 fronts
    Linn AV5120 Center
    Linn AV5140 Rears
    M&K MX-70 Sub for Music
    Odyssey Mono-Blocs
    SVS Ultra-13 Gloss Black:D
  • Ron Temple
    Ron Temple Posts: 3,212
    edited January 2011
    RTis have an edge to the tweeter that does get better, but in comparison to early monitors, they are forward.
    Combo rig:
    SDA 1C, CS400i, SDA 2B
    PB13Ultra RO
    BW Silvers
    Oppo BDP-83SE
  • PrazVT
    PrazVT Posts: 1,607
    edited January 2011
    Yes they are a little edgy at first - I wish I could say for certain that mine warmed up due to the passing of time, but I've added enough gear that it could be that as well. I do know that my A7s sounded brighter with my old Yamaha RX-V663, than they do w/ the Denon/Parasound/Cambridge combo.
    Not sure what Rotel's characteristics are like - but I'd say give it time :) Great speakers, I love 'em.
    Dali Optikon 1Mk2
    NAD D3020 V2
    Schiit Bifrost 2/64
    ..the rest are headphone setups.
  • mdaudioguy
    mdaudioguy Posts: 5,164
    edited January 2011
    +1 to break-in, and as Ron suggested, it may take some time for your ears to adjust, coming from older Monitors. I know Rotel stuff is pretty good quality, but I think I've seen Rotel gear occasionally described as bright, too. (Could be wrong, though). Also, make sure they're getting enough power to really push the low end, as better balance across the entire frequency range may help to provide the needed balance.
    I've been able to mitigate the brightness of my RTi speakers, but I still wouldn't say they're anywhere near as laid back as Monitor 10s.
  • mystik610
    mystik610 Posts: 699
    edited January 2011
    markiki wrote: »
    Thanks,
    Mark
    The RTi-A's are bright by nature. They're more oriented to HT than they are music. The RTi-A7 is also the brightest amongst the RTi-A towers. They will sound a little warmer overtime, and using a warm amp will go a long way, but they are designed to over emphasize the highs a bit.
    I had the RTi8's, and had great results pairing it with a warm amp. But they were always bright to me, and my ears never did get use to them for music. I always found them too bright for music no matter what I did.
    My System Showcase!
    Media Room
    Paradigm Studio 60 - Paradigm CC-690 - Paradigm ADP-390 - Epik Empire - Anthem MRX300 - Emotiva XPA-5
    Living-room
    Paradigm MilleniaOne - Rythmik F12GSE - Onkyo TX-SR805 - Adcom 5400
    Headphones
    Sennheiser Momentum Over-Ear - Shure SE215 - Fiio E18 Kunlun
  • thesurfer
    thesurfer Posts: 574
    edited January 2011
    It all depends on your taste,,, like the old tri-lams,, some said they were to bright,,, others said they were somewhat laid back,, As far as breaking them in,, thats a debate in itself,, some claim, you just get used to the sound,, and think you have broken them in,,, others swear, that certain speakers sound better when play for 40-80 hours, i feel the same,, but, in the end, it comes down to what you like,,, if there bright now,,, to the point where it bothers you,, maybe there just not your cup of tea,, JMO,,,
    Not an Audiophile, just a dude who loves music, and decent gear to hear it with.
  • RuSsMaN
    RuSsMaN Posts: 17,985
    edited January 2011
    They will mellow a bit, your new RTiA's are less forgiving than the 10's, and play out much further on the top end. A little bit is the speaker, a lot is probably the quality (or lack thereof) on the material you are listening to.
    For example, original Beatles releases sound wonderful on 10's, you can hear the compression moreso on RTiA series, and they are all but unlistenable on the LSi(m).
  • Tour2ma
    Tour2ma Posts: 10,177
    edited January 2011
    Were your 10's on stands? If yes, flat or angled? Part of your impression could be as simple as your ears are now at (or closer to) the level of the tweeter.
    What tweeter did your 10B's have?
    More later,
    Tour...
    Vox Copuli
  • nhhiep
    nhhiep Posts: 877
    edited January 2011
    Rti/A series is always bright for music...get TSI/Monitor or LSi series for music
  • markiki
    markiki Posts: 3
    edited January 2011
    Tour2ma wrote: »
    Yes.
    Angled.
    I'm not sure.
  • markiki
    markiki Posts: 3
    edited January 2011
    Thank you everyone. The posts pretty much confirmed what I believed to be the case: Yes, they are bright; Yes, the amp being warmed up helps; Yes, the quality of what I am listening to contributes to the perception of brightness.
