Towers for Surround Duty ?
Do many people use Tower Speakers for surrounds in lets say a 5.1 setup ? As an example, if a person could get 3 mth old RtiA7's for aprox $400 to $450,would they add more to your sound field than lets say the FxiA6 Surrounds ? Or would it just be better to get the Surrounds or Bookshelf speakers. In addition, if you expanded to a 7.1 system,could you Run the RTiA7's on your sides and the FxiA6's or Bookshelf speakers as your Rears. AVR would be a pioneer SC-35 to start with the addition of a seperate Amp later on. The front L and R are Rti10's with a CSiA6 center and an SVS Sub.
Home Theatre.............
Pioneer SC-35
Polk RTi10's Fronts
Polk CSiA6 Center
RTi4 Surrounds
SVS PB-12 Sub
2 Channel.............................
Yaqin MC-100B
Energy RC-70 Speakers
Arcam CD-192 Disc Player
Van Den Hul Interconnects
Pioneer SC-35
Polk RTi10's Fronts
Polk CSiA6 Center
RTi4 Surrounds
SVS PB-12 Sub
Yaqin MC-100B
Post edited by larry777 on
I upgrade the surround LSi7s to LSi15s and never looked back. Along with replacing the LSiC with a PSB Synchrony One center, using LSi15s was a great upgrade.Lumin X1 file player, Westminster Labs interconnect cable
Three 20 amp circuits. -
I tried it using my RTi A7's (5.1) as the rears and I did not like how they sounded compared to my FXi A4's. (Personel opinion)
The 7's worked great in the back and were very clear and did what they were supose to do.
In my opinion I felt that the 7's where not being used to thier potential in the back.
I had them set as small, had 120 w amp driving only those rears and all that came out of them was highs and mids along with ambient sounds. (to me that is what the rears are used for)
I hooked up the FXi 4's and the sound field at the back was fuller and not as directional as the 7's.
I experimented with multi channel SACD and the 7's at the rear sounded better than the FXi A4's.
I have not heard a FXi A6 so I can not comment on the sound and I really think that it is personel taste on how you like your back stage set up. some like it loud and direct, some like it to blend in with the rest of the speakers. "To me", the FXi A4's blend better in my set-up and for my taste.
Good luck, and hopefully you will get some other responses. -
I think it's a good question... I've wondered the same thing. 20 yrs ago 5.1 AVRs offered 100W per channel for the front two speakers and typically 30W for center and rear speakers. So obviously the intent at the time was for "ambient" sound. I think if you want to use your system for DTS NEO6 or some other full "matrix" or discrete music mode you might want to consider equally capable speakers on all corners / sides / rear.
At least that's probably what I'll do once I buy an up-to-date AVR / Pre-Pro.Yamaha RX-V2700, EMI 711As (front), RCA K-16 (rear), Magnavox Console (Center & TV Stand), Sony SMP-N200 media streamer, Dual 1249 TT =--- Sharp Aquas 60" LCD tellie -
Give it a whirl. Thats the fun thing about this hobby,trying different things,seeing what works for you and what doesn't. You could always re-sell at no to minimal loss if you don't like it.HT SYSTEM-
lsi 9's -
I run SDA/SRS 2.3TL's for mains and LSi-15's as surrounds and could not be happier with towers for surround duties. I will never go back to a satellite of bookshelf for that purpose. When I go back to a 7.1 setup, I will consider LSiFX for the two rears, but in 5.1 towers are the way to go, for me anyway.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
Put me in the nooshinjohn camp: many of us use LSi15 as surrounds for various reasons. I bought a pair of LSi F/X speakers that I am using with my Mac, but when I move into a different house (one with a dedicated and larger theatre room), the LSi F/X will be put to use in a 7.1 configuration.
All speakers are set to Large in my set-up.Do you hear that buzzing noise?
Thanks for all the comments everyone. Using Towers as surrounds seems to be a common practice for many people with good results. So it will stay on the table as an option for me also. I am using a 5.1 setup now with the Rti4's for surrounds but I have a second pair of RTi4's to complete a 7.1 system. I may try the 7.1 when my SC-35 comes in but I am thinking towers because I am preparing another H/T Room downstairs using my Denon 888. The RTi4's could go in that room so they won't be wasted and my extra sub ( PSW 505 ) would still match with them ok.Home Theatre.............
Pioneer SC-35
Polk RTi10's Fronts
Polk CSiA6 Center
RTi4 Surrounds
SVS PB-12 Sub
Yaqin MC-100B
Van Den Hul Interconnects -
nooshinjohn wrote: »I run SDA/SRS 2.3TL's for mains and LSi-15's as surrounds and could not be happier with towers for surround duties. I will never go back to a satellite of bookshelf for that purpose. When I go back to a 7.1 setup, I will consider LSiFX for the two rears, but in 5.1 towers are the way to go, for me anyway.
Sounds like your saying you would use the LSI-15's as the sides and LSiFX for the rears. I would likely go the other way.
I am on the hunt for another pair of LS70's or LS90's so I can put towers in the rear of my HT.Polk Audio SDA SRS 2.3TL
Parasound Halo A21
Parasound Halo P3
Home theater
Polk LSiM 707, 706c, 703, 705
Polk Blackstone TL3 for height
SVS PB12-ISD Sub
Denon AVR-X6400h
Parasound Halo A51
LG OLED65B7A
Sony UBPX800
Logitech Harmony Elite
PC LSiM 703
Spare LSIM 702 and 706c
Home Theater #2
Polk Audio LS70, CS350LS, LSF/X, S4
Onkyo TX-NR808 -
I have used and still do Towers for my surrounds and Love it. You be surprised at the bass that comes out of them at times.
Speakers
Carver Amazing Fronts
CS400i Center
RT800i's Rears
Sub Paradigm Servo 15
Electronics
Conrad Johnson PV-5 pre-amp
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Sony CX400 CD changer
Panasonic 42-PX60U Plasma
WMC Win7 32bit HD DVR
