NAD 2200 problem
Harrym
Harrym Posts: 25
edited May 2011 in 2 Channel Audio
I have a NAD 2200 with a little problem. When I turn it on, I get some weird scratchy distortion coming from the left channel. It clears after a few minutes. I have determined that it is the NAD by process of elimination. Could this be the filter caps in the power supply or am I going in the wrong direction.
Any ideas ??
Post edited by Harrym on
  • danger boy
    danger boy Posts: 15,722
    edited January 2011
    you are going in the right directions.. the 2200 and the 2600 series have that problem as they age. very common problem with this age of NAD power amps. old solder joints tend to break in the RCA outputs too.
    PolkFest 2012, who's going>?
  • FTGV
    FTGV Posts: 3,650
    edited January 2011
    Typically if a filter cap is going south you will start to here hum through the speakers and it will get progressively worse,and not correct itself after it's been on a spell.My guess would be a cold solder joint or component like a transistor that is flaky until it warms up.
  • sucks2beme
    sucks2beme Posts: 5,681
    edited May 2011
    Bad solder joint or relay contacts are shot.
