What next after RTi-A5s and Onkyo TX-SR707
ProbeGT
Hi all . . .have been a lurker since I got your thoughts on some stuff during the summer. But now, it may be nearing time to take a next step. You can see my gear in the sig--I'm really liking my new speakers and receiver for probably 70 percent HT and 30 percent music. I do notice the brightness of the A5s on music, and I'm also hearing the shortcomings of my CS20 and my older Cerwin-Vega sub now that I've upgraded the main speakers.
So that's the question--what are your feelings on the best next step: 1) Get an amp; 2) upgrade center to an CsiA4 or A6; or 3)Get a sub?
I know a lot depends on personal preference and HOW MUCH I'm noticing the shortcoming mentioned, but I thought I'd fish for some input--especially with the holidays coming up.
Onkyo TX-SR707 | RTi-A5s | CS20 Center | Monitor 30 Rears | HSU STF-2 Sub
Post edited by ProbeGT on
1. sub
2. center
3. ampTheater: Epson 8500ub, Elite 120" screen, Lsic, Lsi25, Lsifx, SVS Pc12plus, SVS Pc12plus, Emotiva Xpa-5, Denon Avr3311ci, Sony Bdps1000es
Living Room: Panasonic TCP58VT25, PS3, Energy FPS, Onkyo Tx sr707, Sony Ps3, DswmicroPro 2000
Bed Room: Panasonic TCP50x1, Samsung Bd c7500
Weight Room: Panasonic TCP46G10, Polk Pswi225, PS3 -
1-Center
2-sub
no amp needed. -
i agree with leroy center first then sub. Center is one of the most impotant speakers ion your setup. Then you can always add an amp if want to.Music doesn't lie. If there is something to be changed in this world, then it can only happen through music.
-Jimi Hendrix -
normally id agree with center first but the one you have isnt that bad and the impact and wow factor of a good subwoofer, at least to me, trumps the rest of your intended upgrades...but do put some effort into it, dont just go buy a psw10....look into svs, ed, or hsu...get something to compliment those rti's...another thing to think about is dual subs which completely changed my system
and if your center is really hurting your system, you can always turn it off in the receiver and use the towers are l/r/c....i did this for a while and it worked out pretty well....
as you see i also own your receiver and it sounds pretty damn good but once you get all your speakers and subs situated, i would look into an external ampTheater: Epson 8500ub, Elite 120" screen, Lsic, Lsi25, Lsifx, SVS Pc12plus, SVS Pc12plus, Emotiva Xpa-5, Denon Avr3311ci, Sony Bdps1000es
+1 on the sub than the centerRoom Theater:
Fronts:RTIA3
center; CSIA6
AVR: Onkyo 709
panasonic 55"plasma
Ps3 slim 250gb
surrounds.Fxia6
Sub...svs pc13 ULTRA
Amp:Emotiva xpa3 -
My personal choice is sub. when i upgraded to 505 i was really impressed on how much better my system sounded. it might be because i like bass. my vote get a new sub.Marantz SR 7007
polkaudio RTi10
polkaudio CSi A6
polkaudio RTiA3
B&K ST.3140 Power Amplifier
HSU Research VTF2 MK3
Vizio P65-C1
Panasonic 605 blu ray
Onkyo DS-A4 i-pod Dock
Universal Remote
BDI Icon 9429 TV Stand -
If your usage is 70% HT, then I'd upgrade center first.... It does 90% of the work, and almost 100% of the dialog in HT....
Sub next, amp optional.
If you feel you're missing bass, get the sub first, it's not like you don't have a center already.Main Surround -
Den - Rotel RSP-1068 / Threshold CAS-2 / Boston VR-M60 / BDP-05FD -
Can you tell us what "shortcomings" you are noticing? Is the dialogue lacking in clarity, volume, etc? Are you missing what is being said in the movies, or is the musician's voice lacking volume, impact, detail, etc.?
As for the sub and the base you are hearing; what exactly are you hearing, and what do you want to hear?
Have you used the auto calibration at all? What are your current settings for all the speakers? You may need to adjust some of the settings, especially the crossover frequency, as this will have a large impact on the sound of the system.
With this information, we can then help steer you in the right direction a little better.Mitsubishi 60" HD LDP
Polk RTI-A3 L/R
Csi-a4 CC
Polk CSW 10 Sub
Pio. Elite VSX-03
Pioneer BDP-51FD Blu-Ray
Polk Fxi3s for surround.[/SIZE] -
Thanks for the input so far. I decided to do the subwoofer first, and after doing some reading I went with a HSU STF-2 I picked up on Audiogon. Big improvement, and nice!
I would now say that I'm satisfied with my setup's HT performance. But, I'm still not as happy as I ought to me with the 2-channel music end of things. Part of the issue is my system doesn't sound as good as a friend's system that has a set of Klipsch RF-7s. Now, I've accepted that my $800 speakers aren't going to match $2000 speakers, and that my speakers are more suited to HT than music, but I think I can do better and am now thinking amp. I want to de-brighten the A-5s.
From lots of reading on here and other places, I think a Rotel amp may be what I need. I've narrowed it down to three choices, at three price points. Would like your thoughts. Or, maybe you have an even better idea. The main goal will be to give my A-5s some better power. I know that ultimately the most expensive solution would probably be best, but any money I don't spend right here can go to other hobbies. . . :biggrin:- 1. RB-956 (40W x 6) Plan would be to bridge the six channels to 3 and also drive my center. Or, it looks like I can bridge to 4 channels and bi-amp. But would this be enough power to make a difference from my receiver's power? Cost: approx $150.
- 2. RB-976 (60W x 6) Ditto above. Cost approx $250.
- 3. RB-985 (100W x 5) Could bi-amp the fronts, and also run center. Cost approx $450.
Onkyo TX-SR707 | RTi-A5s | CS20 Center | Monitor 30 Rears | HSU STF-2 Sub -
Was going to suggest center then sub but your latest post say you're well on your way!
Enjoy.Marantz AV7005
Marantz MM7055
Onkyo DX-755 CdP
Oppo BDP-93
Technics SL-1301/Shure M97xE
Polk RTi A7s
Polk CSi A6
Polk FXi A6s
Velodyne VDR10-BV
Panamax M5100-PM
Antec VERIS A/V Cooler x 2 -
Well, I was going to wait a while on an amp, but found a Rotel RB-985 on CL for $200 and couldn't resist.
WHAT A DIFFERENCE! I just have it hooked to the fronts right now, but music in 2-channel sounds SO MUCH BETTER. . . it really toned down the brightness, and overall just gives what seems to be a more expansive sonic palette . . . .and individual sounds seem more distinct as well.
Wow. . . I'm very happy I did this upgrade!Onkyo TX-SR707 | RTi-A5s | CS20 Center | Monitor 30 Rears | HSU STF-2 Sub -
Very nice! Have not heard the A5s myself, but many say they are surprisingly good. I'm sure that amp really brings out the best in them. Sit back and enjoy!
Oh, and start saving up for that CSiA6, too! I think you'll be similarly impressed.
