MIT Shotguns vs PNF Icon IC's
Ern Dog
Ern Dog Posts: 2,237
edited January 2011 in 2 Channel Audio
My rig is cabled with PNF's all around for almost a year now and I absolutely love them. I finally had an opportunity to purchase one set of MIT Shotguns S3 IC's and wanted to see how it compared to the PNF Icon IC's I'm using.
In my rig the IC that goes from source to preamp makes the most audible difference rather than the IC from preamp to amp- so that's the one I switched out. I started out with using the medium impedance setting since my preamp is rated at 50 ohms input.
These cables are already broken in. I listen to them for 5 days straight, then today I popped the PNF's back in. Guess what I found out......
They are BOTH excellent cables! The difference between them is very minute if anything to my ears. This was not what I was expecting. I thought the MIT's would sound better. If anything it seemed like the MIT's were a tad darker and had a hint of rolled off highs. Go figure. Again this was soo subtle that I don't believe I could pick out which in a blind test.
Now the cool thing about these MIT's is the impedance switch, so after this first evaluation I reset them both to low and we'll see how they perform with this adjustment. Then I'll try high. So to be fair this shoot out isn't over yet. Also the PNF's have an advantage because there is a synergy that happens when using all PNF cabling. Same is true for MIT's. To really even out the playing field I'd have to go all out with Shotguns with both IC's and speaker cables.
Take this review with a grain of salt, as somebody else may find totally different results in their rig with these two IC's.
More to come as I get more familiar with the Shotguns....
Post edited by Ern Dog on
    VR3 Posts: 29,549
    edited January 2011
    Interesting ---
    I honestly didnt experience a positive difference with my cables until I had -all- of them, interconnects and speaker... that was then it really came together.
    At that point it was a huge difference.
    F1nut Posts: 51,997
    edited January 2011
    Good stuff, thanks for the review.
  • Outfitter03
    Outfitter03 Posts: 563
    edited January 2011
    Very nice review. Ern Dog do you know if PNF is out of business? I posted a thread in the club house section that their site was pulled down and got no replies. I had read some of your earliier feedback on PNF cables and wanted to take a look. In reviewing the posts then I also found some delivery issues that people were experiencing.
    There still is Audiogon to watch for used, but if most of the buyers are as satisfied as you they may be reluctant to let go of their cables.
    You have an impressive two channel system by the way. Thanks for sharing this review.
  • ben62670
    ben62670 Posts: 15,969
    edited January 2011
    The MIT's were a little dark and rolled off in my system too. Also the sound stage was a little narrower. Like you system the biggest difference was between my source and pre. People need to try different setups in their systems though. What worked for us may be different for them.
    Ben
    Ben
    edited January 2011
    Thanks for the review. For me, Ben's silver ic's have had great synergy in my system.
  • Ern Dog
    edited January 2011
    Thanks for all the comments.
    I can only suspect that PNF went under. It wouldn't surprise me due to the growing number of orders not being filled that I read about on this website. Too bad because they made a nice product.
    Trey- I think you're right on about the synergistic effect with the whole rig cabled with the shotguns.
    Maybe someone on the forum would be willing to trade a whole Shotgun cabling system for my PNF cables for a month just to test drive them. I have two sets of 1 meter PNF IC's and a pair of 8 foot biwire PNF speaker cables.
  • inspiredsports
    inspiredsports Posts: 5,502
    edited January 2011
    I wanted to weigh in also about the synergystic effects I've found using MIT from wall to speaker. MIT suggests the full effect of their various components will not be realized unless same grade components are used throughout the chain. My initial thoughts were that it was MIT marketing hype to sell more product, and I wanted to hear for myself.
    I've experimented over the past 2 years with 6-8 brands each of power, interconnect and speaker cables. At each point, I've found MIT's to work best when used throughout the entire circuit.
    I personally wouldn't characterize my Shotgun S2's (interconnects) as being "dark" as some above have stated, but I would characterize higher silver content wires as being brighter and might even use the word harsher. The MIT's are more neutral, and it is accurate to say not bright/harsh. In my opinion, neutral, but clear and revealing are the way I hear them. One characteristic of the MIT's (specifically my Shotgun S2 speaker interface cables) is noticeably improved bass, and not in terms of loudness, just a more focused, tightly controlled and pleasant bottom end. For me, the sound quality improvements have been equally noticeable using both SS and tube amplification.
    I'll also share that I've received a lot of criticism from friends and especially family about the cost of cables, but they do end up in agreement that my rig's sound quality is clearly better. I've forgone a lot of nights out with friends and detuned a family vacation to fuel this hobby.
    The best way to state my belief is that as funds allow, I vote with my wallet and move up the MIT ladder.
    I also want to caution that non-systemic A/B testing of MIT IC's versus other brands may not reveal the entire picture. And as always, my experience is only with my specific system . . . your mileage may vary.
    Conrad Johnson PV-5 w/mods
    MF x-DAC V8, HAInfo NG27
    NAD SS rigs w/mods
    GIK panels
    F1nut Posts: 51,997
    edited January 2011
    I agree that the benefits from using MIT cables are better when the entire rig is connected with them. Although, I have to say that I have heard vast improvements from a single pair of MIT IC's added to a rig, more than once.
  • phipiper10
    phipiper10 Posts: 961
    edited January 2011
    Hey we should organize an MIT Demo so everyone could hear MIT throughout their rigs........aaaaaa...........hhhhhummmm...........nevermind.
    Analog Source: Rega P3-24 Exact 2 w/GT delrin platter & Neo TT-PSU Digital Source: Lumin U2 w/Roon (NUC) DAC:T+A DAC 200 Phono Preamp: Rega Aria MK3 Preamp: Rogue RP-7 Amp: Infigo Method 6 Speakers: Joseph Audio Perspective 2, Audio Physic Tempo Plus Cables: Cardas Clear Reflection SC/IC, Shunyata PCs Misc: Shunyata Hydra Delta D6, VTI rack, GIK acoustic panels
  • Conradicles
    Conradicles Posts: 6,376
    edited January 2011
    phipiper10 wrote: »
    I thought we were...oops...my bad...:biggrin:
  • pearsall001
    pearsall001 Posts: 5,327
    edited January 2011
    Had them (Shotgun S2 speaker cables & IC's) heard them...sold them... they just didn't bring anything to the table as far as I was concerned. Everyone's rig is different & I'm certainly glad I gave them a shot in mine even though they didn't impress me.
  • Ern Dog
    edited January 2011
    There are so many Shotgun fans on this forum, that I figured it was worth giving them a listen for myself to make my own conclusions.
  • pearsall001
    edited January 2011
    Ern Dog wrote: »
    That was exactly the same reason that I gave them a listen. I figured with so many MIT fan boys singing their praises that they must be on to something. Boy was I wrong. No big deal that I was dissapointed with them. I'm just glad that I recouped my money when I sold them.
    F1nut Posts: 51,997
    edited January 2011
    We are on to something, better sound.
  • Polkitup2
    Polkitup2 Posts: 1,642
    edited January 2011
    Just shows that everyones gear and ears are different. My personal MIT experience was positive with both W4S, and Musical Fidelity gear. In fact, I just went all balanced wth my W4S set-up and at first bought some inexpensive Mogami ICs, bad move. Switched to MIT cables and all is well. :smile:
  • pearsall001
    edited January 2011
    Nothing more than a subjective opinion...in which case mine disagrees completely. Not all manufactures products can please everyone. And if they could, this would be one boring hobby.
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    edited January 2011
    it is always best to use the same cable throughout your rig.
    I use MIT.
    RT1
  • B&W802d
    B&W802d Posts: 72
    edited January 2011
    Thank you for sharing your experience with them. I tried to like MIT a few years ago and in the end I enjoyed them about as much as I like the end result of eating chips cooked in Olestra. Talk about a WTF moment in audio for me. They sure do make one hell of a neat jumprope though. I may just order some PNF stuff to try out and if it's a no go give them to my son or one of his friends.
    heiney9 Posts: 25,497
    edited January 2011
    B&W802d wrote: »
    My WTF moment was listening to B&W's, thought maybe someone shoved ice picks in my ears.............B&W's make great targets at the shooting range though. :rolleyes:
  • B&W802d
    B&W802d Posts: 72
    edited January 2011
    heiney9 wrote: »
    I agree. Nothing like shooting some lower end B&Ws and watching them splinter all over the place. We should meet up for a B&W shootathon.:biggrin:
    edited January 2011
    B&W802d wrote: »
    A new member with a sense of humor and doesn't take this site or hobby too seriously. :biggrin:
  • B&W802d
    B&W802d Posts: 72
    edited January 2011
    heiney9 wrote: »
    If I did take what you said seriously I would need to take my **** on down to mamby pamby land and listen to some Bose hooked up to some Emo amps,lol.
  • inspiredsports
    edited January 2011
    B&W802d wrote: »
    Hmmm . . . pretty astute verbiage for a 31st post here at CP . . . a second username for an established member, perhaps? :biggrin:
    NAD SS rigs w/mods
    GIK panels
    txcoastal1 Posts: 13,519
    edited January 2011
    I second that all in good fun and opinions w/o BS...:smile:
  • B&W802d
    B&W802d Posts: 72
    edited January 2011
    New member as far as posting goes but I have stalked behind the scenes for years. I feel as if I know most of the regs here even though I only recently started posting. I know the ins and outs, everyones button,gear you have now or had in the past,etc. from reading thorough this site every week. I figured I might as well post a little and stop being a 'lightman' and hiding outside everyones window.:eek:
  • reeltrouble1
    edited January 2011
    prove it....name the WoodShed gear........waaaaaaaaaaaaaaaa
    btw did you know Polk voiced their car audio speakers to a b&w...I do think it may of been the 802.
    RT1
