Advice on hooking amp to receiver
DON73
I have a Pioneer 1120 and will be using an Adcom 7500 connected to the preouts on the receiver to power B&W 801s fronts, B&W 803 rears and B&W 805 center. The amp is THX certified and Adcom suggests THX cables between the receiver and amp. They also say that THX speaker cables should have spade connectors at the speakers.
Do I really need to seek out THX interconnects or will a well made RCA cable work just as well? Spade connectors are easy but I already have cables terminated with banana plugs that fit very tight. Any suggestions will be a big help.
A forklift would be helpful placing the monstrous 7500.
TO ERR IS HUMAN. TO FORGIVE IS CANINE.
Post edited by DON73 on
A well made rca cable will do just fine. THX is simply a marketing gimick that cost more money.Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2
Congrats on the amp, and yes, a good quality rca cable for each channel is needed,and no,it doesn't have to be thx certified. Speaker cables will work as they are too. Check out signal cable, good quality at a good price to start out and get you rolling. Enjoy.HT SYSTEM-
lsi 9's -
Thanks cfriz and tonyb. That's a lot of cables and it's a little crowded behind the units and I'm not as flexible as I was a few years back.TO ERR IS HUMAN. TO FORGIVE IS CANINE.
Eh, who is ? I guess your twister playing days are over. Join the crowd. Let us know how things work out for you or if you need further help. Cheers.HT SYSTEM-
