Advice on hooking amp to receiver
DON73
DON73 Posts: 516
I have a Pioneer 1120 and will be using an Adcom 7500 connected to the preouts on the receiver to power B&W 801s fronts, B&W 803 rears and B&W 805 center. The amp is THX certified and Adcom suggests THX cables between the receiver and amp. They also say that THX speaker cables should have spade connectors at the speakers.
Do I really need to seek out THX interconnects or will a well made RCA cable work just as well? Spade connectors are easy but I already have cables terminated with banana plugs that fit very tight. Any suggestions will be a big help.
A forklift would be helpful placing the monstrous 7500.:smile:
TO ERR IS HUMAN. TO FORGIVE IS CANINE.
Post edited by DON73 on
  • cfrizz
    cfrizz Posts: 13,415
    edited January 2011
    A well made rca cable will do just fine. THX is simply a marketing gimick that cost more money.
    tonyb Posts: 33,072
    edited January 2011
    Congrats on the amp, and yes, a good quality rca cable for each channel is needed,and no,it doesn't have to be thx certified. Speaker cables will work as they are too. Check out signal cable, good quality at a good price to start out and get you rolling. Enjoy.
  • DON73
    DON73 Posts: 516
    edited January 2011
    Thanks cfriz and tonyb. That's a lot of cables and it's a little crowded behind the units and I'm not as flexible as I was a few years back.
    tonyb Posts: 33,072
    edited January 2011
    DON73 wrote: »
    Eh, who is ? I guess your twister playing days are over. Join the crowd. Let us know how things work out for you or if you need further help. Cheers.
