What Type of Banana Plug
PolkNewb
PolkNewb Posts: 45
edited January 2011 in Electronics
What type of banana plug should I choose? An open screw style or closed screw style?
Post edited by PolkNewb on
  • 98Badger
    98Badger Posts: 317
    edited January 2011
    Whichever ones makes a secure connection. I like the GLS locking bananas.
    GLS locking bananas
  • fbm211
    fbm211 Posts: 1,488
    edited January 2011
    Xhadow banana plugs are a great option if you dont mind paying a lot.
    Furez are a great budget option and they are pure copper.Stay away from the cheap plated garbage.
    Silver plated copper is ok though.Thats what I used to terminate my speaker cables.
    SDA-2BTL with custom IC
    Harman Kardon T-55c TT
    DH LABS REVELATIONS ICs-amps
    Revelation Audio Labs Paradise cryo-silver ICs-Source to pre
  • PolkNewb
    PolkNewb Posts: 45
    edited January 2011
    How about the banana plugs sold on Monoprice.com?
    Tony M Posts: 11,728
    edited January 2011
    These are the one's I'm using the most now a days. the 1260's.... but the little set-screw down ones 356's above them are pretty good for the price also.
    http://www.parts-express.com/wizards/searchResults.cfm?srchExt=CAT&srchCat=108
  • kawizx9r
    kawizx9r Posts: 5,150
    edited January 2011
    GLS Audio locking plugs are the **** :cool:
    Truck setup
    Alpine 9856
    Phoenix Gold RSD65CS
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
    Any clue how to use the internet? Found it in about 10 sec.
  • Polkie2009
    Polkie2009 Posts: 3,834
    edited January 2011
    I really___ like what GLS Audio did on their banana plugs with the 2 screws,thanks for the pic kawizx9r.
  • zingo
    zingo Posts: 11,258
    edited January 2011
    I just installed some solder plugs from DH Labs, and they are great as well. Gold over pure copper and they work very well.
  • toucanet
    toucanet Posts: 581
    edited January 2011
    I currently have spade ends that I do not want to cut and am looking for a banana adapter that can connect to the spades and be used accordingly with my gear.
    What is a good one for connecting to spades?
  • Face
    Face Posts: 14,340
    edited January 2011
    Vampire or WBT.
  • toucanet
    toucanet Posts: 581
    edited January 2011
    edited January 2011
    Stinger Bananas work with spades also.
