HDMI / composite conn. Q
recover
I've got an Onkyo TX-NR708 reciever. Now I'm using my X-box to play my movies. My TV has the yellow composite video connection and the s video conn. only. As of now I'm using the composite video cable. I was wondering if I could run the HDMI cable to the reciever and then from the reciever use either the s-video or composite to the TV. If not would using a DVD player with a s-video conn be better than the X-box for movies be better since the x box dosen't provide the s video conn
Post edited by recover on
I've got an Onkyo TX-NR708 reciever... I was wondering if I could run the HDMI cable to the reciever and then from the reciever use either the s-video or composite to the TV...
Yes it will work. However you will not have 1080p. be prepared for more like 480p or most likely 480i resolutions.
BTW you might have gotten more input if you had placed this thread in the video games section of this forum.
gl/hf/gg
EDIT: Welcome to CP!
:biggrin:Integra DTR 50.2 used as a preamp
Rotel RCD 1520 cdp
AudioQuest Jaguar 72v dbs ic's
AudioQuest type 8 wire
biamped to:
2-Hafler 9500 trans nova's
AudioQuest NRG-3 power cable's
dedicated AC line for
Tesla Plex 20a duplex receptacle
Panamax Max 7500 pro surge/line conditioner
SDA SRS 3.1 TL's modded...
spikes, rdo's, rings, dynamat, sonicaps, mills & aeon
Panasonic Viera G20 50" plasma
...SDA's are just like candy for your ears... -
Your TV must be pretty old to only have composite connections. Might be time to go see what your missing in the way of HD.HT SYSTEM-
lsi 9's -
So...what are you saying Laz ?
lsi 9's -
A new TV is definately on the wish list!! Just tring to make the best of what I have untill I get one. My thinking was by running an HDMI from the x box to the reciever would at least improve the SQ of the movies. Just wasn't sure if the video signal would go through the composite cable going out from the reciever to the TV. The tv does have an s video jack would using a dvd with the s video be better?
You might want to try it both ways, as I found going from a S-Video source to receiver to change it into HDMI was worst then S-Video to tv directly.
Speakers
Carver Amazing Fronts
CS400i Center
RT800i's Rears
Sub Paradigm Servo 15
Electronics
Conrad Johnson PV-5 pre-amp
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Sony CX400 CD changer
Panasonic 42-PX60U Plasma
WMC Win7 32bit HD DVR -
My TV only has composite connections too!!!!:biggrin::biggrin:
I'll NEVER upgrade to HD!! I think standard definition pictures look vastly better than high definition pictures anyway!!!
HDMI sucks! Composite A/V is where it's at!!!:biggrin::biggrin:
Don't give in!! Keep your old school TV and never go HD!! It's a waste of time!!The nirvana inducer-
APC H10 Power Conditioner
Parasound Halo P5 preamp
