Niles amps common ground?
fishbones
fishbones Posts: 947
edited January 2011 in Electronics
I have a gentleman coming over to audition my SDA's and he has a Niles SI-275. He wants to come over tonight and bring his amp (cause I am ampless) he hasn't been able to get ahold of Niles over the past few days cause of the holiday to find out if it's common ground.
Anyone know?
Post edited by fishbones on
  • ben62670
    ben62670 Posts: 15,969
    edited January 2011
    I have to be blunt. Niles amps suck bad for HiFi. If you need to get by with one just take a multi meter and measure across the grounds on the speaker terminals. If you get next to no resistance then it is common ground.
    Ben
  • fishbones
    edited January 2011
    Thanks Ben. You'll probably laugh because of your knowledge, but could you give me more instruction (is amp on, setting on MM to use)?
  • ben62670
    edited January 2011
    Sorry. Nothing hooked up to the amp. Unplugged. Take and measure the resistance across the ground terminals on the amps speaker outs.
    Ben
  • fishbones
    edited January 2011
    What setting should I use on the multi-meter? Ohms? 10,100,more setting?
    Sorry, I own one but don't know how to use it.
    Thanks again...
  • ben62670
    edited January 2011
    Set the meter on the lowest setting. If it doesn't read at a low setting it is not common ground.
    Ben
  • fishbones
    edited January 2011
    Okay, I decided to dig out an old reciever I have (Lafayette) and hooked it up to the 2 negative terminals on speaker outs with the unit on. I had my MM set on Ohms, at the 200 setting (the lowest). It starts higher, but drops down instantly to waiver between 1.2-2.2.
    Does this sound like I'm in the right territory for common ground?
    Thanks again...
    Troy
  • dorokusai
    dorokusai Posts: 25,576
    edited January 2011
    You don't even need to do that. Check for continuity between the negative binding posts....if you have it, common ground, if you don't....you don't.
  • fishbones
    edited January 2011
    dorokusai wrote: »
    I think I checked that too? There is a ground setting on my MM with a buzzer and light. I connected the two negative terminals and the buzzer and light went off. How's that sound?
  • dorokusai
    edited January 2011
    Like common ground.
  • fishbones
    edited January 2011
    Cool, thanks guys for all the help!!!
