200 wpc amplifiers
jmwest1970
I'm looking for something in the 200 wpc plus range. Adcom GFA-555, NAD 218THX, or Parasound 218THX is what I've been looking at.
Thanks,
Michael
Thanks,
Michael
Post edited by jmwest1970 on
What will be the other associated components used with the amp?
Are you set on those 3 amps?
Someone will probably also ask what your budget is.
Any specific reason for 200wpc?
In a vacuum, I would choose the GFA-555design is where science and art break even. -
The amp will go into my 2 channel rig and I'll be using the Cambridge integrated as a pre.Are you set on those 3 amps?
No. Those are examples of the amps I've seen that fit the bill.Someone will probably also ask what your budget is. Any specific reason for 200wpc?
My budget is $400 or less and I want 200wpc to provide maximum headroom for the Rainmakers. I'll eventually move to another speaker in my 2 channel rig and I want to have power available no matter what I choose. The Adcom is a great amp, but I'm impressed with the NAD and Parasound HCA-1200II as well. I'd love to have the high end Cambridge, but that's way out of my price range. -
I like B&K. Older series like the 2220, 4420, EX442 would fit the bill...... ><////(*>
I have a BK ST202+ which isn't doing anything. If you're interested, I'll check on it's current condition and let you know.
Does this need to have high WAF? I have a professional series Crest 4000 that is stable down to 2 ohms if you are interested....Computer room Hegeman 1 SpeakersM&K VX-80 subKenwood DP-7010Cambridge Audio CXC Transport Rega DACPrimaLuna Prologue Four AmpAric Audio Tube PreampGarage Jennings Research SquareCustom tube preampCrown XLS-1000Denon DCD-1500II Modded MSB Link DAC
I have a couple of NAD 218thx available.SRT For Life; SDA Forever!
The SRT SEISMIC System:
Four main satellite speakers, six powered subs, two dedicated for LFE channel, two center speakers for over/under screen placement and three Control Centers. Amaze your friends, terrorize your neighbors, seize the audio bragging rights for your state. Go ahead, buy it; you only go around once. -
I really like B&K too in the $400 range. Sometimes you can find the reference 200.2 for around that price. Maybe a little more.
I have a Parasound HCA-1200 mkII that I really like that can be found for that price.
Also, theres someone on the forum who really likes this HCA-1500 amp.design is where science and art break even. -
I have a gfa 555 II
Consider a 200 wpc Rotel RB-1080 if you can find one.
I had both an Adcom GFA-555 and the Rotel and kept going back and forth between them, I eventually chose the Rotel and sold the Adcom.
Did a lot of blind testing with different music types between the amps with a musician friend whose ears I trust. We consistently picked the Rotel.
It could be that the Rotel was newer (fresher caps etc.). An older Adcom would likely be cheaper to buy, but if it needs a refresh, it might end up to be be the same or more than the Rotel.Norh ACA-2B tube pre, Sumo Andromeda SS amp. Magneplanar MMG speakers, M&K MX1250 Subwoofer, Pro-Ject RM1.3 Genie TT with Sumiko Pearl MM cart., Keces DAC, Cambridge Audio Azur 640c CD player -
Carver is good stuff too and they have multiple high power designs that are well priced on the used market.
jmwest1970 wrote: »I'm looking for something in the 200 wpc plus range. Adcom GFA-555, NAD 218THX, or Parasound 218THX is what I've been looking at.
Thanks,
Michael
Hi Michael,
I have an Adcom GFA 555 II in near mint (9/10 due to age) condition, no visible flaws, performs excellently, and has original box and packing. I would sell for $400 shipped. Good luck with your hunt!!!
JamesOnkyo Pr-sc 5509
Parasound 2250/Parasound 5125
SVS PB 12 Plus
Denon DBP-2012 Bluray
Polk RTI 8, CSI 3, 4 FXI 3
Sony 55" LCD -
starkiller wrote: »Does this need to have high WAF? I have a professional series Crest 4000 that is stable down to 2 ohms if you are interested....
WAF is not an issue, but I'm not interested in professional series amps. The fans drive me nuts!I have a couple of NAD 218thx available.
PM sent.Are you interested in class D for the amp?
I won't rule one out. What did you have in mind. -
There is a Parasound HCA 1000A near me for $150 (Craigslist).
I have the gfa555 w/ what I call the industrial stye w/ the handles. I've run the thing all
day and has never got hot or even to warm. Got it w/ shipping for $300 at Audio Classics
who are pretty good to deal w/ .....LW2chl- Adcom GFA- 555-Onkyo P-3150v pre/amp- JVC-QL-A200 tt- Denon 1940 ci cdp- Adcom GFS-6 -Modded '87 SDA 2Bs - Dynamat Ext.- BH-5- X-Overs VR-3, RDO-194 tweeters, Larry's Rings, Speakon/Neutrik I/C- Cherry stain tops Advent Maestros,Ohm model E
