Help Me With Receiver Selection and stands
PolkNewb
PolkNewb Posts: 45
edited January 2011 in Electronics
Hey guys, FINALLY after a year of planning I have finally started to pull the trigger on my H/T system. I have purchased the TSi 300 towers and the TSi 100's. The tower package came with a free monitor series PSW 10 sub (which will be upgraded to the PSW505 as soon as I get the system put together). I now need help selecting a receiver, I did have my eyes on the Onkyo SR707 but I missed the boat and that has gone up significantly in price.
What does everyone think about the Onkyo TX-SR608 receiver? Would it fit my package well? I will also be using the CS20 center channel.
Also please throw me any ideas for a good, attractive durable stand for the TSi 100's.
Thanks!
Jeff
Post edited by PolkNewb on
    txcoastal1 Posts: 13,518
    edited January 2011
  • leroyjr1
    leroyjr1 Posts: 8,785
    edited January 2011
    I would at least get the 707/708 and up onkyo. They have pre outs which means you'll be able to add an external amp in the future.
  • polkfarmboy
    polkfarmboy Posts: 5,703
    edited January 2011
    I think onkyo and polk are awesome
    I had the 607 and it was great but you could buy a 707 so you can add an amp later . A707 can be bought cheaper than a 608 that has no pre outs
    Wood technology are the best value stands
  • PolkNewb
    PolkNewb Posts: 45
    edited January 2011
    Thanks guys, the stands look great. I read some of the reviews on the 608 and there seemed to be alot of video problems with that receiver. I think I will stick with the 707.
  • PolkNewb
    PolkNewb Posts: 45
    edited January 2011
    another quick question on the stands, how much size platform wise will I need for the TSi 100's?
  • dorokusai
    dorokusai Posts: 25,576
    edited January 2011
    1 inch smaller than the actual dimensions would be ideal.
  • DON73
    DON73 Posts: 516
    edited January 2011
    I ordered a pair of Wood Tech. stands for my monitor 7s and can say they are well made and go together easily. I ordered the ones made of real wood instead of mdf. I liked them enough that I ordered another pair. They are not cheap but they look very nice and they're solid.
    TO ERR IS HUMAN. TO FORGIVE IS CANINE.
