What's the best way to brush your teeth??
Toolfan66
Not sure if I have been doing it right all these years..
Just thought I would look to you guys on an Internet audio forum for advice on what and how you guys do it!!!
Lonesome with out a life in Littleton...
Post edited by Toolfan66 on
2 minutes 30 seconds: 30 seconds each for top outside/inside, bottom inside/outside then 30 seconds for tongue, roof, and tops
then flossing and listerine, of course! :biggrin:design is where science and art break even. -
I find that a comb works better for me than a brush...The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
I dip my finger in my coffee and rub that around my mouth for a full 12 seconds. At night I substitute beer or scotch.SystemLuxman L-590AXII Integrated Amplifier|KEF Reference 1 Loudspeakers|PS Audio Directream Jr|Sansui TU-9900 Tuner|TEAC A-6100 RtR|REL T/9X SE Sub
TOOLFORLIFEFAN wrote: »Not sure if I have been doing it right all these years..
Some ideas for you!!!Pio Elete Pro 520
Panamax 5400-EX
Sunfire TGP 5
PS Audio GCPH phono pre
Sunfire CG 200 X 5
Sunfire CG Sig 405 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Yamaha DVD-S1800BL/SACD
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404 -
Lots of good ideas here! http://www.polkaudio.com/forums/showthread.php?t=107599
Go downtown on a hottie:eek:
Floss and an electric toothbrush. Never had a hygienist tell me I was doing a "good job" until I got an electric brush.If you will it, dude, it is no dream.
bobman1235 wrote: »Floss and an electric toothbrush. Never had a hygienist tell me I was doing a "good job" until I got an electric brush.
Bullseye!Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2
