Can I run 4ohm speakers on an 8ohm system?
RGuz
Hi, I'm new to the forum. Right now I'm running an Sansui 9090 with Cerwin Vega LS-15's. I've just recently bought a pair of Polk RTA-12C's not knowing that they were 4ohm speakers. I was hoping to keep the Cerwin-Vega's on the A switch, and the RTA-12C's on the B switch so I can switch back and forth according to the music that I want to listen to. The Cerwin-Vega's, I believe, are 8ohm speakers. And the RTA's are 4ohm. I'm not sure the difference and don't want to ruin anything. Can I do this?
Post edited by RGuz on
http://www.polkaudio.com/forums/showthread.php?t=102050&highlight=txcoastal1
Here is where is was at several month's ago there are tons of threads including amp choices and opinions mentioned in the threads
Welcome to CP2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
Yes, but the amp's power output is not matched to the load and 1/2 of the output power will be lost as heat in the amp's final output stage. This will limit your amps max power ouput delivery to the speakers and may case the amp to overtemp if operated at sustained levels above 1/2 its rated RMS output level. The amp might trip off with overcurrent protection on the peaks well before it trips off from overtemp.'65 427 Shelby Cobra
'72 Triumph TR-6
__________________
'88 Polk SDA SRS 1.2, with upgraded XO caps and Erse SDA inductors
'86 Polk SDA CRS+
'84 Polk Monitor 10A (Peerless tweeters)
'05 HSU VTF-3 Sub (Original OEM)
'20 HSU VTF-3 Sub (three more, 100% cloned)
'93 Carver TFM-35
'88 Carver M-1.0t
'88 Adcom GFT-555
'88 Adcom GFP-555
'88 Adcom GFA-555 (upgraded/restored)
'88 Adcom GFA-555 (a second one upgraded/restored)
'05 Onkyo DV-555 media
'89 Fosgate 360 Digital Space Matrix
'89 Fosgate 360 Digital Space Matrix, internal surround amp bridged to drive only a center channel
'91 Kenwood Basic M1D Amp
'89 Pioneer Laser Disc media
'89 Sony SuperBeta HiFi media
One PGA2310 based custom built remote volume control
Four Polk T-15's
Four Polk TSi-200's
Four Polk TSi-100's
Two Polk CS-10's -
I believe the old Sansui's can handle 4 ohm speakers. You should double check on the specs. Do you have the manual for it. Look on the back of the unit. Big receivers from the 1970's normally handled 4 ohm speakers because 4 ohm speakers were common in the day. As long as you are not running both A and B speakers at the same time you should be o.k.Polk HT system 1: LSIC, LSI25 mains, LSI F/X rears, Lsi F/X rear centers,
Yamaha RX-V2500 System, Carver A753 3 channel amp.
Polk HT system 2: , SRT system with f/x 1,000's rear speakers on 7.1 system currently using Onkyo TX-RZ820 receiver, powered by Sunfire Grand Theater amp
Polk Speaker collection: SDA SRS 1.2tl x 2, SRT system, SDA SRS 2 P/B, SDA 2A, SDA 1C Studio, SDA CRS+, Monitor 7B & 4, SRS 3.1tl, RTA 15tl, LS90, LSI 9 -
Here is a couple quick links hope this helps
http://www.audiokarma.org/forums/showthread.php?t=339880
http://forums.klipsch.com/forums/p/24943/206974.aspx2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
You could, but I wouldn't. It's not rated to handle 4 Ohm loads. It's a nice vintage receiver, there is a good possibilty you'll mess it up...
