Carver TFM-15, worthwhile
specd_out
specd_out Posts: 505
edited January 2011 in Electronics
I am sure the question I am going to ask gets asked alot by us newbs, but I am trying to learn as I go so I will ask it anyway.
I just purchased a Pioneer elite vsx-32, My mains are Rtia5's. My dad has a Carver TFM-15 that he no longer needs, its just been boxed up for several years. He has reverted back to a sansui amp with some late 60's early 70's Altec lansing speakers.
My question is, Is it worth it to purchase the Carver amp from him and use it to power my mains via the 32's preouts?
I dont know alot about amplifiers but I am learning. What I do know is that in most cases dedicated amplifiers have a much higher quality sound then what comes from AVRs. I also know that Watts dosent really mean much when comparing quality. The carver is rated at 100w continuous and the Pioneer is at 110.
This amp does have some sentimental value to me. i grew up listening to my dad using this amp with his Polk rm3000 system. Thats what actually led me to purchase polks in my own home.
Any input would be appreciated.
HT Rig Samsung 64F8500 |Pioneer Elite BDP-52FD|Pioneer Elite VSX-32| Two Carver TFM-15cb Bridged for mains|Polk Audio RTiA5 Cherry|Polk Audio CsiA6 Cherry|Polk Audio T-15 Heights|Polk Audio FXia6 Surround|DIY 8cuft Dayton Ultimax 15" powered with a Crown XLS1000
2Channel Rig Polk Audio LSi9 Cherry| Carver C-1BillD Mod|Carver M1.0t MkII Opt2|Pro-ject RM 1.3|SpeedBox S|AQ King Cobras|AQ Rocket88|
ISF Level 2 Certified Calibrator
Post edited by specd_out on
    treitz3 Posts: 19,963
    edited December 2010
    Good morning and I hope that Santa was kind to you. While I have not owned the Pioneer Elite you refer too, I have owned a plethora of receivers over the years and it was a pleasant surprise to find out that one of the lowest of Carver separates sounds better that what you currently have in your rig. Don't Bi-amp and as long as you are driving more than a 6ohm load [preferably an 8ohm load], you should be golden. This little gem even bested a Denon integrated, to my surprise.
    While it is not a powerhouse, it should bring out more detail and separation in the music. What does he want to hook you up with it for?
  • thuffman03
    thuffman03 Posts: 1,325
    I have owned 2 of these amps and was never disappointed.
    Sunfire TGP, Sunfire Cinema Grand, Sunfire 300~2 (2), Sunfire True Sub (2),Carver ALS Platinum, Carver AL III, TFM-55, C-19, C-9, TX-8, SDA-490t, SDA-390t
  • specd_out
    I love it. The difference between the AVR amp and the carver is quite noticable. Things sound much fuller and it has a nice warm sound to it. Bass seems to roll off nicely rather then just hitting harder. I either want to get this or get a tfm-25
    I toe u so.
  • gdb
    gdb Posts: 6,012
    Get you a 55 or a 75 !:cool:
  • specd_out
    If money was more readily available, I may consider a higher model. I just bought my vsx about a week and a half ago, If i want to by more stereo stuff I need to sell some extra stuff I dont use otherwise the wife will kill me.
  • gdb
    gdb Posts: 6,012
    Sell the wife.:wink:
  • thuffman03
    You will benefit with some more power. I would recommend the TFM 25 with your speakers. 225 wpc will do nicely and won't break the bank.
    Keep the 15 for your rear speakers or if it is the TFM 15cb bridge it into your center. It is 280 watts bridged!
  • specd_out
    gdb wrote: »
    Yea. speakers dont complain :)
    Thuffman
    I do want a tfm25. I just need to sell my old AVR and some other bs items i dont need. I have been keeping an eye on ebay.
    Whats a good price for a tfm25. From what I have seen they are price at near 400 but the tfm 45 is at 450-500 so to me the 25 seems high
  • thuffman03
    Contact this guy: Tom @ www.vintagehifishop.com
    I know he has a few that are in the middle of being completely gone through and having them brought back to spec. He can give you a better idea of price.
  • specd_out
    ok I will. thanks
    edited January 2011
    The M-500t would be an excellent choice for his setup.
  • newrival
    newrival Posts: 2,017
    edited January 2011
    Seems like all good advice to me :biggrin:
  • specd_out
    edited January 2011
    i found a tfm 15cb local for cheap on CL. I am gonna see if i can grab that. In the future i will grab a second one and run them mono.
