How big is your...
PSOVLSK
PSOVLSK Posts: 5,397
edited December 2010 in Electronics
HT and screen?
I may be moving to a new house and my HT will possibly be a smaller room. My current room is about 16x13 and I have a 110" screen. Any PJ owners throwing a 110" picture from a distance of 14'? I've done the online calculations, but I wanted to hear from people with first-hand experience. So, what are the dimensions of your HT and what size screen do you have?
Post edited by PSOVLSK on
  • B Run
    B Run Posts: 1,888
    I have a 110'' screen in my bedroom, with the projector mounted right above my bed. It's exactly 18' from the front of my projector to the screen and I absolutely love it. I know it's 4' longer but the picture never seems to big or unnatural and I think you'd be fine. My buddy has the same projector and screen in his theater room and I think his 14' and works great.
  • zarrdoss
    zarrdoss Posts: 2,562
    110" @ 11.5 feet and love it!
    So it sounds like you can project that large from that distance? That's good to know. We have a room that was two rooms. We knocked down the wall between them and have an arch at about 12.5' away from the wall. If I were going to mount a PJ, I'd need to put it in the middle of the arch. The viewing distance is a few feet behind the arch...about 16 ft. away? Sounds like that would work.
    cnh
  • Sherardp
    Sherardp Posts: 8,038
    Room is rougly 13x21. With the screen size at 126". My row seating starts at 12 feet.
  • nguyendot
    nguyendot Posts: 3,594
    25 x 25 ft, 100" screen. 12 ft throw.
    B Run,
    do you have a 4:3 screen? Your projector is 4:3 so I wonder about your widescreen movies....
    Main Surround -
  • decal
    decal Posts: 3,205
    Not another mine is bigger than yours thread.
  • cstmar01
    cstmar01 Posts: 4,424
    100" and the room is 14X20ish I think.
    I sit around 12 ft back
  • B Run
    B Run Posts: 1,888
    nguyendot wrote: »
    B Run,
    Nope it's a 16:9 screen, it really doesn't look bad at all when I watch HD channels on cable. Actually until you mentioned it I never realized it was a 4:3 that's stretched haha.
  • PSOVLSK
    It seems like I'll be okay in a room that's about 14'x12'. Very good to hear. Thanks for the help.
  • Sherardp
    Yep you should be fine. Add one row of curved seating, and your good.
  • leroyjr1
    leroyjr1 Posts: 8,785
    210" 2 feet back.
