Oppo 83se
NeilGabriel
NeilGabriel Posts: 1,487
edited December 2010 in Electronics
I am kicking myself for not doing an upgrade on my unit. All online sellers seem to be out. Any random listings are gone in 5 minutes.
Are there any brick and mortar stores that carry OPPO that might have a few units left?
thx
Post edited by NeilGabriel on
  • vc69
    vc69 Posts: 2,500
    Not that I know of. You might check with NuForce and see if they can do anything.
    http://www.nuforce.com/hi/products/oppo_bdp83se/index.php
    -Kevin
    2 Channel:
    Oppo BDP-83 SE
    Squeezebox Touch
    Muscial Fidelity M1 DAC
    VTL 2.5
    McIntosh 2205 (refurbed)
    B&W 801's
    Transparent IC's
  • NeilGabriel
    Sounds good albeit pricey...so this is essentially an 83-SE further modded?
    Anybody have one of these? I assume this is good value?
  • vc69
    vc69 Posts: 2,500
    No personal experience, but I have read good things. NuForce developed the SE upgrade for Oppo and their version is a bit "more knocked out". I was thinking that they may still be UG'ing the standard 83's to SE. (They were at one time). Give them a shout.
    -Kevin
    2 Channel:
    Oppo BDP-83 SE
    Squeezebox Touch
    VTL 2.5
    B&W 801's
    Transparent IC's
  • steveinaz
    steveinaz Posts: 19,546
    Check www.audioadvisor.com they carry them.
    Hold up, all they have is a $2500 unit! Ouch : http://www.audioadvisor.com/prodinfo.asp?number=EXOPPO83
  • vc69
    vc69 Posts: 2,500
    steveinaz wrote: »
    Good grief. If that isn't a typo, it's an absolute travesty.
    -Kevin
    2 Channel:
    Oppo BDP-83 SE
    Squeezebox Touch
    VTL 2.5
    B&W 801's
    Transparent IC's
  • jayman_1975
    jayman_1975 Posts: 672
    I have an Oppo BDP SE Nuforce. Pretty awesome player
    Onkyo TX NR 5008 modified by The Upgrade Company
    Oppo BDP 93 modified by The Upgrade Company
    Arcam CD37
    Monitor Audio Gold GS 60
    Revolver Audio Music 5 towers.(surround)
    Vandersteen V2W
  • blueboxer
    blueboxer Posts: 621
    Nuforce had a couple on their site about three weeks ago, but I have not seen any since. Oppo had a return for cheap as well, that lasted all of a couple hours. There is a 93 reasonably priced on the gon.
